Old 12-05-2016, 01:23 AM   #1
todds66
Suspension help
I have a 1966 C-10, the rear is lowered with a C-notch from PBfab and air bags, the remaining rear suspension components are stock. I also have the front lowered with air bags, 2 1/2" dropped spindles and stock A arms. The remaining front is riding on stock components. Bottom line is that after lowering my truck it rides like a log wagon. Can I please get some input on those running either of PBfabs stage 1 or 2 and the quality in regards to ride. I will also be buying the shocks to go with the set up from PBfab.
1966 Custom Cab SWB SBW Fleetside
1968 C10 BBW SWB Fleetside
todds66 is offline   Reply With Quote
Old 12-05-2016, 11:55 AM   #2
LVPhotos
LVPhotos's Avatar
Re: Suspension help
Too much air? The KYB shocks Porterbuilt recommend are available at local Auto zone. Unless you got some long shocks bottoming out, or too stiff you should have decent ride. What bags and psi? The Firestone are stiffer than Slam.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-06-2016, 01:24 PM   #3
todds66
Re: Suspension help
LVPhotos I am not sure of the brand air bags, all work was done at a shop. Air pressure is set to 70psi in rear and 25psi for front for driving. It looks like there are Monroe stock shocks at all four corners. The shocks are in the stock location in the rear so it appears they are at an elongated position. Do you have another suggestion on brand of shocks?
Old 12-06-2016, 01:41 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Suspension help
No rear shock re-locators?
Old 12-06-2016, 02:38 PM   #5
LVPhotos
LVPhotos's Avatar
Re: Suspension help
Air in back should be less, me 40. Front more, me 80-90 just to clear fenders. My bags are Firestone 2500 rear and 2600 front. Play with pressure but you are not running enough in front and too much rear. But it's more of hieght vs pressure. The rear has to be stiff with that much air. I run 70psi in my helpers on my 1 Ton with 5th wheel hooked up.
Old 12-06-2016, 02:54 PM   #6
Clyde65
Clyde65's Avatar
Re: Suspension help
My rear bags, 2500, run at 45 in regular driving.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-06-2016, 04:26 PM   #7
todds66
Re: Suspension help
No shock re-locators. Stock positioning. I will play with the air pressure.
Old 12-07-2016, 01:57 AM   #8
todds66
Re: Suspension help
Anyone with suggestions of another suspension set-up or manufacturer that they're satisfied with please chime in.
Old 12-07-2016, 08:38 AM   #9
PGSigns
PGSigns's Avatar
Re: Suspension help
Your pressures seem like they are flipped. You need to take a look at your shocks and see how much travel you have left front and rear. Also if you can post some pictures of your setup so we can see what you have. On the shocks measure them at ride height and then you can look up the part number an see what the compressed length is. That will tell you the amount of travel you have left. Were the bump stops removed from the front? Also what tires are you running? Tires can make a huge change in the ride.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-09-2016, 04:38 PM   #10
todds66
Re: Suspension help
PGsigns, the front stops have been removed from the front. I am running 255/45/18 in the rear with 235/45/18 up front.
Old 12-09-2016, 05:38 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Suspension help
The rear shocks in that stock brackets setup lays them too flat to actually work.
Add some rear shock relocators or even better the Porterbuilt rear shock bars and shocks.
Keith
Convert to disc brakes.
Old 12-09-2016, 11:19 PM   #12
LVPhotos
LVPhotos's Avatar
Re: Suspension help
Todd ,I have my '62 shock mounts which would flip location of the lower shocks to front. If interested pm me.
Old 12-10-2016, 09:40 AM   #13
PGSigns
PGSigns's Avatar
Re: Suspension help
Are these pictures at ride height or fully aired out? if they are at rude height its easy to see why it rides bad.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-11-2016, 02:44 AM   #14
todds66
Re: Suspension help
Thanks for info. The pictures (sorry for improper angle) are at ride height. I was looking at the PBfab set up thanks.
Old 12-11-2016, 09:28 AM   #15
PGSigns
PGSigns's Avatar
Re: Suspension help
The bags look almost compressed fully at ride height. It looks like it has very little travel before they are on the internal bump stops. I think a set of cupped a arms and getting rid of the spacer on the top of the rear bag will improve the ride issue.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
