12-06-2016, 01:51 AM | #1 |
Vintage Air heater 506101
I am planning on installing a Vintage Air heater 506101 into my 1957 and have been searching for pictures of how this unit has been installed by others. I have not been able to find any. Does anyone have the procedures for install into the 1955-59 trucks or maybe some pictures of how they installed the heater?
The instructions from VA is generic and show the unit installed in the middle of most vehicles. Thanks Last edited by bmar; 12-06-2016 at 01:54 AM. Reason: picture |
12-06-2016, 02:58 AM | #2 |
Re: Vintage Air heater 506101
I do not recall anyone using that. I got a used VA sure fit and had it in and out 3-4 times to get the fit right. Looking at the install instructions things I would look for are interference between the fan housing and wiper motor and linkage; check the defroster routing, you will probably need to get a pair of the 55-59 under dash defroster vents, they bolt right up, but are towards the front (firewall). You might think about mounting it more to the passenger side where the stock unit went.
12-06-2016, 09:10 AM | #3 |
I believe most are using the VA Gen IV for the TF trucks. Roger55's build has some great info/pics.
Cheers, Jim |
12-06-2016, 12:25 PM | #4 |
Isn't the price of that heater almost as expensive as the a/c unit? It might be worth the extra dollars to have heat and a/c.
12-06-2016, 04:23 PM | #5 |
The heater is $229 plus I will need to buy a few more fittings.
I put a vintage Air system into my '77 Corvette and by the time I bought all of the brackets (Holley), compressor, lines, fittings etc. the price was almost 3 grand. I also bought the equipment for install the freon...The truck can be my "beater with a heater" |
12-06-2016, 04:34 PM | #6 |
The truck has a fuel injected 5.3L engine, so it will also require the parts to be bought separate.
12-06-2016, 06:30 PM | #7 |
I recall seeing a build thread of one being installed in an AD. His installation was real simple. It bolted to the firewall, plumbed the coolant hoses, power, switch and done.
12-06-2016, 10:16 PM | #8 |
I believe that is the same heater I installed in my '53 build, sure looks like it. The truck isn't on the road yet, but the install was very easy, and it works great. I have some pics of the install, but I don't know how to download to this site.
12-06-2016, 11:54 PM | #9 |
I am also interested in how the three knobs were installed. I would like to mount the three controls on the dash and not leave them in the factory mounting.
12-07-2016, 10:00 AM | #10 |
This is why I went to the Southern Air mini max1 for my 408cid LQ9 6.0. $1029 with high mount bracket for a/c,defrost,and heat. The only extra you had to buy is heater hose. They cannot set the standard length and you can get that at autozone for about $20. VA has went beyond the price standards in my opinion. It is just blowing air hot and cold...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon. |
12-09-2016, 07:31 AM | #11 |
I have one pre installed in my '49 truck , please see my build thread.
Maybe it helps to Gent ideas... |
12-09-2016, 08:25 AM | #12 |
Looks like a nice compact unit...I guess not many people use it I have looked at it also but could not find much for reviews.
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
12-09-2016, 03:19 PM | #13 |
I guess I will need to take a lot of pictures when I install this :-). I am surprised there has not been plenty of these units install. But then living in Montana really cuts down on the need for air conditioning, so just the heater will be fine with me.
Most of the installs have been in the middle of the vehicle, but there is the radio and the RainX wiper unit in my truck. So, as OrrieG said, off to the passenger side like the original heater. I can remove the controls and the plates under the knobs come off also, so I can mount them anywhere on the dash. The knobs will be the hard part. Maybe I will try something like the knobs in the picture. |
12-09-2016, 04:27 PM | #14 |
My install was as far right as I could go, as high as I could go, under the dash. My glovebox just fit though I may shorten it about an inch just to have sufficient space to get my hand up in there. I ran my hoses in the stock firewall holes. The trouble with the switches is the size of them (the part behind the dash hole), one of them is pretty large, I believe the on/off/speeds, so you have to have room behind the dash to mount them.
12-09-2016, 06:16 PM | #15 |
I have two ash trays that I ended up with, neither of them I will be using, since I don't smoke. I could cut the back out of one of them and maybe install the knobs into the front of the ash tray. I also have two controls that came stock in the trucks, but I don't see how I could mount the knobs. If I could find some kind of potentiometers that matched the VA, and hooked them up to the sliders on the old heater controls......seems like an awful lot of work, but maybe.
12-12-2016, 08:44 PM | #16 |
just purchased one for socal customs sacramento off their website looks like a compact unit for a little over $200 plus shipping. I will let you know how it goes
12-13-2016, 01:03 AM | #17 |
I also just bought a kit today from Speedway Motors. I have been trying to decide how to install the controls and have settled on the old heater control panel. I have been using the same style of knobs on my dash and these are the last three that I have. I will need to line the back with something and I would still like to have the background light.
12-19-2016, 06:51 PM | #18 |
bmar... from Libby? Are you, or were you, a GM tech once upon a time?
12-20-2016, 01:04 AM | #19 |
12-20-2016, 01:50 AM | #20 |
No problem. I sent some parts for a '56 to a gentleman out that way back when I lived in Hardin. We were both GM techs at the time.
Stay warm! |
12-20-2016, 03:15 PM | #21 |
I have an original heater than has just been repainted and recored.
it will look 10 times better. 602-510-2519
http://http://67-72chevytrucks.com/v...d.php?t=489721 |
12-20-2016, 04:05 PM | #22 | |
I never had a heater in either of the trucks I started with, I also like the electronic controls instead of the old manual cables and this heater seems to be a nice compact unit that will fit under the dash. |
12-22-2016, 12:43 AM | #23 |
The Vintage Air heater arrived today and I have studied how the controls can be mounted on the original heater control. I just have a mock-up for now and I will need to add spacers to the controls and one of my levers is broken and will need to be replaced. The heat control rotated almost 360 degrees, so there was no way to attach it to the original controls. The knob shows where I will install the control and use the knob showing in the pictures. I will need to tap the levers where the original knobs would have been located.
I will drill and tap these tomorrow and make up the spacers and post some more pictures. The heater control will need to be installed from behind the dash and the chrome face screwed back on from the front. The light still works, but I will remove the lettering since it doesn't corresponded to any of the controls. Last edited by bmar; 12-22-2016 at 12:51 AM. |
12-23-2016, 02:26 PM | #24 |
I couldn't get enough sweep of the levers to reach all the setting on the control knobs. I needed about another half an inch in order to have all the settings... so I am back square one. I still don't really like the idea of knobs on the outside of the heater control assembly.... I wasn't that sold on just the one knob, let alone three knobs.
12-26-2016, 11:10 AM | #25 |
The heater I have is the factory cheap heater. comes with the manual defrost .
I used a carburetor that has an automatic choke. I didn't need the choke knob, soThat's where I put the heater control, and the original heater hole was filled with a blank off plate from the factory.
