12-07-2016, 02:34 PM | #1 |
Rear hinge pins
Are the rear hinge pins the same size as the door hinge pins?
Who makes the rubber gasket around the barn door hinges? Thanks in advance |
12-07-2016, 10:15 PM | #2 |
Re: Rear hinge pins
12-08-2016, 11:17 AM | #3 |
Never Ending Projects
Re: Rear hinge pins
IIRC, Steele Rubber makes the hinge gaskets.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
12-08-2016, 03:44 PM | #4 |
Re: Rear hinge pins
Thanks Pad and Mike for answering my questions.
Are the outer barn door hinge gaskets the same size as the 40-59 suburban? |
12-08-2016, 04:11 PM | #5 |
Re: Rear hinge pins
if you look in the link that I gave you and fill in the listing for what you have and check it out. you will seek the knowledge that you are inquiring about
don't know whether or not if they are the same size as the earlier ones. but they have what you need. ron Last edited by padresag; 12-08-2016 at 04:17 PM. |
12-10-2016, 08:15 AM | #6 |
Re: Rear hinge pins
Does anyone make the plug that goes into the holes for the barn doors if the Sub has the clamshells? I've checked Steele, and others but all they carry is the grommet for the hinges
Thanks |
12-10-2016, 01:01 PM | #7 |
Re: Rear hinge pins
think that maybe you are SOL there !
ron |
