My 85 C10
Hello Everyone, I am in the middle of an ls swap on my 85 C10.
Tons of parts purchased... Needs body work like a dead man needs a cofffin. But here we go. So far, Here's somewhat of a parts list... '98 LS1/4L60e I have had complete sitting in my shop for 12 years or so. (also have an L33 & a 4L80e I may throw in the truck instead) 1 set of 243 heads & 1 set of 799's at the machine shop getting cleaned up. Plan in ditching the heads on the LS1 currently. Lokar LS1 48" throttle cable Lokar throttle cable bracket-billet Part #TCB-40LS1 Tejas Metal Works transmission mount (Will be switching from the Dirty Dingo motor mounts to Tejas Metal works) Drive shaft was made at DriveTrain of Mesquite in Mesquite Texas PSI engine harness for LS1/4l80e 411 PCM, ditched the '98 PCM Lunati double valve springs Comp Cams pushrods Lokar billet column shift arm kit Part #ACA-1800 Spectra Premium 31 Gallon tank for an 87-91 K5 Blazer or a Suburban Part # Spectra Premium Sending Unit Part # Walbro intank pump Corvette Filter/Regulator Used a mix of Earls&Russel fittings for -6AN fuel line Taylor 9mm Spark plug wires NGK Iridium Plugs Pace Setter long tube headers for 98-02 Body Wheels-22" Coys Pirelli tires 265/35r22 on the front, 285/35r22 in the rear. DJM drop spindles/coils front, flip kit rear (Competition Specialties Triangulated 4link with coil overs going on the rear soon along with Ridetech control arms Upper&Lower)
1964 Coupe Deville(cruiser) 1966 Chevy II Nova 2door Hardtop 1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys 2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s 2000 Trans Am WS6, LS1/T-56, too many mods to list |
Re: My 85 C10
I guess some pics are needed!
Ls1/4l60e are in the truck. Need some opinions on adapting the 4l80e to the LS1. I know Circle D have stalls available, but I believe the stall speed is only up to 3000rpm for their 278mm.
![]() Transmission crossmember Ebay billet steering wheel Fesler billet lock knobs Lokar Billet throttle cable bracket
Re: My 85 C10
used 2 Earl Fittings to adapt to the two Metric fittings on the feed & return ends of the sending unit to -6AN
Re: My 85 C10
Removed these center hood hinge springs. Started installing these hood struts from Wamrods!!! Awesome product!
Re: My 85 C10
Notice the cable end of the rod. To use the Lokar throttle cable with the clevis end, the split at the end could be a problem. It also wont work with it running parallel with the firewall.
1964 Coupe Deville(cruiser) 1966 Chevy II Nova 2door Hardtop 1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys 2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s 2000 Trans Am WS6, LS1/T-56, too many mods to list Last edited by PunishedC10; 12-13-2016 at 12:50 PM. |
Re: My 85 C10
looks like youre getting it knocked out! keep it up!
Re: My 85 C10
Trying too! Working 30 hour shifts and off for 18 hours with no days off this year has really killed me having much time haha. Hopefully I'll have everything put together by the end of January. I plan on taking it all apart after that and having the frame and tons of other stuff powder coated in Hobbs, New Mexico.
I am going to try and knock out most of the body work while the frame is there then get it all back together.
#9 | |
Re: My 85 C10
#10 | |
Posted via Mobile Device |
Re: My 85 C10
I finished up the Wamrods hood strut kit install today. Well worth it!
Re: My 85 C10
Re: My 85 C10
Re: My 85 C10
Not sure how my pics came out sideways
#15 |
Went with a 278mm Circle D 4l80e 3000-3200rpm stall convertor. Got it in about 3 business days. Looks amazing!!! Excellent customer service
#16 |
I also ordered a TCI flexplate that is dished like the ls1 flexplate and the convertor is made to fit the flexplate of the ls1/4l80e. Part number for the flexplate is #399753
#17 |
Re: My 85 C10
Sign me up! My square is an 85 too and I have a 5.3/4L60E just waiting... I like where you are going so far, especially with the suspension.
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! ![]() 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
#18 |
Re: My 85 C10
I’m sure the vent windows will be top notch. Their fee is reasonable compared to what it would cost me to do myself. By the time I break them apart, but new parts and get them sandblasted/powdercoated, I think it would cost me over $500.
#19 | |
Re: My 85 C10
If you use the camaro LS3 or L99 waterpump like I am using, it will line up with the truck accessories of your 5.3 and you can use a short uppoer radiator hose like I am using instead of running one across your radiator.
#20 |
Re: My 85 C10
Today I cleaned up a bunch of small stuff that I have been needing to do. Also got the passenger side Schoenfeld header bolted up.
#21 |
Re: My 85 C10
Glad to see you're keeping at it. That's a neat truck. What is it that you do that has the long-haul shifts like that?
#22 | |
#23 | |
Re: My 85 C10
#24 |
#25 |
The survice I primarly provide is perforating. I send down explosives into the well and I shoot perforating guns to make holes in the casing (pipe). Frac then pumps sand through those holes. The thing is we usually only do an area of 100-200’ at a time. Frac will pump sand. Then we send more guns in and shoot more holes, then they frac again.
