![]() Join Date: Mar 2014
Gas Gauge and Boyd Fuel Tank
Anyone know how to make a 64 C10 gas gauge work with a new Boyds aluminum gas tank and Boyds fuel sender. Is it an ohms issue?
Re: Gas Gauge and Boyd Fuel Tank
Reading on other forum the solution is a 50 ohm resistor or an adjustable reostat. But I am going old tank to new gauge. I need to see if my float is still floating. Speedway Motors had a video on YouTube or Autometer.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
![]() Join Date: Jan 2011
When you order the tank all you have to do is select the 0-30 ohm sender. Mine works fine in my 66. You will be good to go.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Join Date: May 2010
Yep that's what I did.
It only has original paint once |
+3, specify the 0-30 ohm sender and you'll be good.
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
![]() Join Date: Aug 2014
My 30 ohm sending unit works perfect from Boyd's? Works great with my stock gauge.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
I did the same but it's tough to gauge how accurate it is when it's less that a quarter full. Anyone seen this?
I've always had that problem even with the stock tank where accuracy rapidly falls off below 1/4 tank. I'd be curious to know if it has anything to do with the sensitivity of the narrower range (0-30 as opposed to 0-90 ohm).
