12-15-2016, 02:47 PM | #1 |
73-87 long bed 2wd 4 link coil over set ups.
I have a long bed 2wd its fairly low and i am upgrading to a 4 link since i have just completed my own custom notch. What i mainly want to know from anybody running a long bed 2wd is what brand coil overs are you running and what spring rate. Part numbers will help. I want to know everything including preload , spring length , travel. i am going to weigh and order my own but i want to see what other people are running and if they like it / if it works well on street.
instagram - @custom.chevy |
12-15-2016, 02:48 PM | #2 |
Re: 73-87 long bed 2wd 4 link coil over set ups.
Fab work.
12-15-2016, 02:54 PM | #3 |
what it looked like before i started the notch and 4 link. yes it bottomed out the rear so i couldn't drive it anyway.
12-15-2016, 03:11 PM | #4 |
doing some research on the topic myself i found that brothers sells a parallel 4 link back half essentially that comes with 220# springs on a 5 inch stroke shock. Now if they just sold only the coil overs.
its hard to believe what 4 link kits cost, when the only expensive component is the coil overs. Rod ends/bushings and tubing is dirt cheap anymore. Just have to be confident in your welding/fab skills.
12-15-2016, 03:37 PM | #5 |
I have coilovers all around on my 01 GMC Single Cab Stepside with a triangulated 4 link out back. Fronts are 12", 800lb. Rear is 14", 225lb. Coilovers are RideTech HQ Series. I could not be happier with them.
Your spring rates may be a little different, but should be close. I started with 250lb springs in the rear and they were just too stiff. Springs are pretty cheap, so it doesn't hurt too bad to do a little experimenting. |
