go bucks!
can you buy just the frt.cab mounts?
anyone got a source to buy JUST the front cab mount bushings in rubber? rear of cab have already been done just need the ones in the floor well area.......the butt-head who did my truck noticed that it was easier to just replace the rear cab mounts as they thread up into the cab from the bottom into a welded nut in the cab...... frt. ones go down from the floor pan and the head/washer of the bolt is tack welded to the floor pan.....h#ll which is no big deal,.....but there's a lot of morons out there who think it's easier to half-a$$ things.
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
LMC Trucks sells the cushions, bushing/sleeve , bolts, and torque nut separately.
I bought a Cab mount kit from another supplier, but only used the front mounts. The back mounts were still good. It's nice to use all new hardware, instead of reusing the old stuff eg. bolts, nuts,washers.
Nelson 1970 C10 350 Auto. A/C not Working |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Just go to the GM dealer. They sell them seperately.
2A674 Tank Rat
GMCPauls sells them too.
'92 GMC Sierra, Sportside, 2wd, 350, Black '92 Chevy Silverado Extended Cab 4 x 4, Blue USAFR = 2A674 = Aircraft Fuel Systems Maintenance i.e. Tank Rat |
For what it runs for a whole set, I'd just do all 4 while I was at it. Just my $0.02....
go bucks!
thanks to all for the replies!! i'll prolly check w/ my local chevy dealership....at the end of my road makes it convienient!!
