Old 12-23-2016, 04:40 PM   #1
ACII
4l60e output shaft too much play ???
Hy all....
after i was able to get some miles on my truck this year....i had to recognize that i have a Kind of Vibration of the drivetrain at around 60 mph ....
Also i have a leaking rearshaft seal....
So therefore i have dissambled the driveshaft today....
Next week i will bring the driveshaft to a shop for balancing..
Also i checked the Output shaft of the 4l60e.... pls have a look at the Video:
https://www.youtube.com/watch?v=BY7R...ature=youtu.be
Do u think the Play / movement of the shaft is normal ??
thanks a lot and i wish a happy Christmas time !!
CU
Achim
ACII is offline   Reply With Quote
Old 12-23-2016, 05:00 PM   #2
truckdude239
truckdude239's Avatar
Re: 4l60e output shaft too much play ???
Seems alot but some of the shafts are held center bu the yoke which riding in a bushing
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 12-23-2016, 08:29 PM   #3
65standard
65standard's Avatar
Tailshaft house and bushing might be worn out
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 12-23-2016, 10:48 PM   #4
ls1nova71
ls1nova71's Avatar
You need to put the yoke in and check it, you cant tell without it in there.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-24-2016, 12:22 PM   #5
95 S_Trucker
95 S_Trucker's Avatar
The yoke supports the output shaft. There will be tons of play when the yoke isn't installed. If there is play in the yoke after you install it, the bushing in the housing is worn. In extreme cases, the yoke can be worn.
The video you posted is normal.
95 S_Trucker is offline   Reply With Quote
Old 12-25-2016, 05:50 AM   #6
ACII
Hy all together.....
thanks for ur Response !!
Next week i will Balance the drive shaft and install a new rearshaft seal..
so i hope the vibrations will be gone... otherwise i will remove the rear housing and check the bushing..
thanks again for ur help and have a nice Christmas time
CU
Achim
