12-26-2016, 10:04 PM | #1 |
1964 c10 long narrow/step bed
I have been wanting a 64-66 c10 for years with full air ride and to lay frame. I started my search strictly for a short bed but was open to either bed style. Years of searching only revealed "I'm going to fix that one day" or overpriced swiss cheese paperweights. I knew I was not going to use 90% of the c10 I purchased, so I did not want to spend a lot of money on something I was going to junk anyway. Since I knew I was going to go full air ride and lay frame, I knew I needed to find a high hump transmission cab if at all possible. A random day on Craigslist found a 1964 c10 long narrow/step bed. This combination was not my first choice but it had the high hump transmission cover and the price was too good to pass up. On top of that, when I tell people my project, they automatically assume a short wide but they question the existence of a long narrow/step with "I don't think I've ever seen one of those". To which I reply.."exactly". The day I brought the c10 home:
The tear down began, stripping everything and tossing what I wasn't going to use: Typical rust: The frame was junk slowe made a cab dolly out of the old frame and proceeded to use a different frame (also pictured is a cab lift jig I made from a thread on here): Some pics of the extent of the rust. I've ordered all new patch panels and ran braces to the factory hinge/jam to keep the cab straight (hopefully): |
12-26-2016, 10:16 PM | #2 |
Re: 1964 c10 long narrow/step bed
Since I cannot weld, I was either forced to utilize all bolt on suspension components or have someone build my chassis for me. I wanted to be the builder of my own project, so I went with GSI front suspension and Porterbuilt rear suspension. The GSI front suspension went together relatively pain free, just the minor tweaks here and there. The rear suspension has been a little more difficult and time consuming due to one issue coming up from solving another. The rear is for the most part mocked up. I have been in contact with Nate over at Porterbuilt with the issues that have arose. To his knowledge, I'm the first that is bagging a long narrow/step bed and there will be some issues that come up because of that.
Rear suspension fully mocked, just need some tweaks once I get the bed panels on: Front suspension mocked up: I did have a mock up 5.3 and 4l60e in the frame rails for the front suspension mock up. Just like the Porterbuilt front dropmember, the GSI utilizes a rack and pinion steering with a couple joints to get from the rack to the steering column output shaft. |
12-26-2016, 10:37 PM | #3 |
It's been difficult to determine the maximum overall tire diameter the step bed will allow but I've read it's 28". I was able to find some original 6 lug 15" steel wheels from the 60's, however after I converted the front to 6 lug disk, the backspacing would not allow the wheel to clear the front caliper. From there I found some 70's 6 lug 15" steel wheels and they clear the caliper. I am using a 215/75/r15 tire for mock up (they were on the wheels already) and that tire with the weight on the truck equals to about 26.5", which does not allow my rear suspension to have enough up travel because it's designed for a 30" tall tire. I also needed to see if the bed sides were going to need to be clearanced for possible tire interference. I attempted to utilize my stock bedsides but after removal of the rusted angle strips, there were pin holes and swiss cheese all behind where the angle strips were. I put the numbers to fixing the rust and straightening out the stock bedsides and I was going to be money ahead to buy new bedsides from Mar-K and since they are located an hour and half away from me, it was a pretty clear decision. The entire bed will be all new sheet metal minus the cross sills I will still be able to use, which is three, possibly four. I got the bed mocked up and on the frame, all to cycle the rear suspension. When trying to lay out the rear suspension, the bed side contacted the axle tube before the frame was on the ground. I wanted to make a nice clean clearance around the axle tube so I drew up this template in ACAD at my second job and was able to use a grinder with a cut off wheel and hack saw blade in order to made the radiased cut around the axle tube:
12-26-2016, 11:00 PM | #4 |
Ordered the 63-72 c10 fuel tank from Boyd Welding on their black Friday sale. I knew I was going to remove the factory crossmember somebody had torched to fit a receiver hitch, so I got a GSI rear crossmember to replace it at the end of the frame. Removed the old crossmember and dropped the fuel tank in between the frame rails to get an idea of what it would look like. I also had to remove the cross sill closest to the back of the notch. I would like to keep that cross sill, so I'm still trying to figure out what I'm going to do there:
With the bed mods done and the wheels and tires on for mock up, I was finally able to cycle the suspension as a whole. This is with the frame fully laid out: |
12-27-2016, 12:49 AM | #5 |
Nice.
That's a lot of work. Look forward to loads of reports and pics.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
12-27-2016, 01:28 AM | #6 |
Nice looking build. The long bed will make it appear lower. Why was the frame junk?
01-17-2017, 03:01 PM | #8 |
Looks good. I am not usually a fan of step sides but when they are laid out I love them.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
03-07-2017, 09:47 PM | #9 |
Realized it's been a while since I've posted. I got my steering shaft support tab welded up to the control arm/upper bag mount. Also spent a little more time figuring out the best wheel/tire combo for the front and rear. Planning on 18x8 Mobsteel wheels with a 225/55r18 tire. That size tire should keep me from having to mini tub the rear and still provide adequate articulation at ride height before contacting the inner bed panel.
03-17-2017, 09:55 PM | #11 |
My 64 long step had a factory spare carrier between the cab and fender. I was beginning to wonder if mine was factory because all I saw was the spare tire in the fender cut out, even on the long step, however I have been seeing a few lately in the same location as mine. Mine was pretty mangled so I had a local shop make an exact replica, only offset from the fender a little more to accommodate the extra backspacing of the wheels I'm going to run. Hopefully I measured right.
03-20-2017, 06:03 AM | #12 | |
04-10-2017, 10:26 PM | #13 |
Picked up this beauty the other day. It's in better shape than the two 63-66 hoods I have and has no through rust.
05-10-2017, 10:18 PM | #14 |
I got the wood cut, a couple gas struts and a bunch of mounting hardware and decided to give it a shot. This what I've got so far. The gas struts are rated at 50lb force each. I took an old cotton scale and held the tilt portion of the bed up at the desired angle and took a reading. It said 80lbs so I figured 100lbs total should lift it up. When the floor is closed the gas struts are horizontal.
When I try to open, its very hard and no assistance is provided by the struts. Once the floor gets going vertically, the struts take over and help raise the floor to the extended length. I'm wondering if I need to mount the struts at an angle when it is closed in order for the struts to assist in lifting from the very beginning? Maybe I need a higher rated force strut? |
07-22-2017, 12:06 PM | #15 |
It's been a little since i posted but I ended up re-configuring the location of the gas struts. I turned them the other direction to more mimic a tonneau cover and also got a little stronger rated gas strut. With those two changes the cover opens and closes with ease. I also mounted the spare tire carrier to the bedside. I still need to fab a support on the inside of the bed panel for extra support but that shouldn't be too difficult.
07-22-2017, 12:44 PM | #16 |
The drool is heavy on this one.
01-09-2018, 09:22 PM | #17 |
Sorry it's been a while since I posted but I've been busy with roof/cab repairs which included finding another cab because after I pulled the outer roof skin on mine, I confirmed what I suspected. Rust in the a-pillars, door frame pieces above the door and inner roof skin/headliner. So the cab hunt began but luckily I found one local. Ironically it had better roof pieces but the floor was in way worse shape than mine so the dismantling of the a-pillars and inner roof pieces began. After removal, I had them blasted and did the required rust repair.
