Old 12-27-2016, 01:32 PM   #1
Swedchevy67
Lower arm setting
Wonder if it's important to set the lower arm in position with the notch and pin?
Swedchevy67 is offline   Reply With Quote
Old 12-27-2016, 02:55 PM   #2
davepl
davepl's Avatar
Re: Lower arm setting
Yes. Yes it is.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 12-27-2016, 03:04 PM   #3
Swedchevy67
Originally Posted by davepl View Post
Yes. Yes it is.
I did remove the arm to clean it up and forget to
look at the notch!!!
What could happen? Will it move back and forward.
Do you suggest that I do it right?
Than you
Stefan
Old 12-27-2016, 03:16 PM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
Yes to all of the above. If and when it moves, it will affect your alignment.
How did you get it to seat without it going into the hole? Isn't there a gap now between the cup and u bolt?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-27-2016, 03:39 PM   #5
Swedchevy67
That's just the odd! I can't see any gaps! But I am sure that I missed it when I
mounting it in place.
If I jack the lower arm and loose the bolts round the cup, do you think I can turn
the support arm right?
Old 12-27-2016, 04:09 PM   #6
67ChevyRedneck
Probably... hopefully you installed them correctly, they are different L and R (notch and hole would be on opposite sides)
Jesse James
Project "On a Dime"
Old 12-27-2016, 04:27 PM   #7
Swedchevy67
I missed that too!!! I think?
Thank you
Old 12-27-2016, 11:26 PM   #8
Guy67UK
Guy67UK's Avatar
I'm lost as to what you mean here. Do you have any pictures to show exactly . I had to take my bottom arm off of the drivers side after it got damaged when the front wheel came off when all the wheel studs sheared
Guy67UK is offline   Reply With Quote
Old 12-28-2016, 12:30 AM   #9
Swedchevy67
https://goo.gl/images/m3wUOF
Look at this link
Old 12-28-2016, 12:44 AM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
My antivirus software stopped me from looking at your link. Anyway-
If you got the lower control arm shaft to seat into the frame, that is one thing. But you need to make sure that the distance, as measured per the manual, is set correctly, or you will NEVER get the caster set correctly. You really need to either search the internet or get the service manual (recommended) so that you repair your truck properly, to avoid personal injury or property damage.
~Steven
Simi Valley, CA
Old 12-28-2016, 02:12 PM   #11
davepl
davepl's Avatar
This looks like an aftermarket tubular lower control arm in the picture. I can only tell you what I know based on the stock original control arms.
They need to be installed with the little "dent" or "hole" lined up properly with the nub or pin or whatever you want to call the part that seats into it.
Even if you had it somehow in the perfect position, without the pin it would likely move around over time. So I think you need to verify it.
If you do not have this correct your "wheel alignment", which is to say the direction the wheels are pointing, will never be stable. It will likely always change and drift and make the truck unsafe and no fun to drive.
Or it might just all work out fine anyway, but if I were you I would want to know that it was done right.
I'm afraid to tell you, but I think you should (safely!) take it apart again and check.
Old 12-28-2016, 04:23 PM   #12
weq92f
weq92f's Avatar
Some pictures from the thread:
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 12-28-2016, 05:34 PM   #13
weq92f
weq92f's Avatar
the pin...
Old 12-29-2016, 10:53 AM   #14
Swedchevy67
That's the notch, I know. I will make sure it is in place. Thank you
Old 12-29-2016, 10:51 AM   #15
Swedchevy67
Your absolutely right! I will do so. Thanks
Old 12-29-2016, 10:57 AM   #16
Swedchevy67
The picture is from the Internet and not from my truck. I just wanted to illustrate what I mean. Stefan
Old 12-28-2016, 04:20 PM   #17
weq92f
weq92f's Avatar
Have a look at this thread below. It has all the details you need including pictures...
http://67-72chevytrucks.com/vboard/s...masher+whacker
-klb
