Speedometer Driven Gear and Drive Gear?
Are the drive gear and driven gear paired up?
In other words... Can I just change the driven gear to get my speedometer to read faster than it was? If I change the driven gear, will the change work or will the gears not mesh correctly? My speedometer was off by quite a bit, at 65 I was reading 50. GPS is a wonderful thing to test this! Thank you, Bill ![]() ![]() 3987917 17 tooth 3987918 18 tooth 3987919 19 tooth 3987920 20 tooth 3987921 21 tooth 3987922 22 tooth
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
Re: Speedometer Driven Gear and Drive Gear?
You can play with different gears or just use a ratio adapter. Look here in the speedo section.
https://transmissioncenter.net/shop/ |
#3 | |
Should I remove it to see if it is a ratio adapter? Bill
The older ones looked different and some had changeable gears.
Take it out and then check your speedo. It might get worse, it might get better. All you might need is a driven gear change. |
#5 | |
Started with a 20 tooth from previous owner.
Tested it with 18 tooth and it was further off. Put in a 22 tooth and it was closer. ~10mph lower reading at 55 on GPS. The 23 tooth gear diameter was too large to fit!?!? I will try to get the gear ratio and tire size to figure out exactly what gear combination I need. Bill
https://transmissioncenter.net/shop/...ar-calculator/
Good info here. I changed my driven gear and came real close to actual speed
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Looking at the online calculators, most are asking for "Speedometer Revolutions Per Mile".
How can I figure this out? I have an L6 with stock 6cyl. in dash Chevy speedometer 6468321. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! Last edited by bill3rail; 12-31-2016 at 10:08 AM. |
#9 | |
Looks like you might need to change your drive gear since the driven gears won't get you close. That can be a lot of fun if you've never done one before. I find it easier just to use a ratio adapter. But to each his own! |
#10 | |
The truck had a ratio adapter on it, which I removed. After removal, it became closer to GPS reading.
Tags |
transmission speedometer |
