01-03-2017, 01:29 PM | #1 |
How can I lift my 68 2wd c10?
I have a 68 c10 it is 2wd I wanna lift it about 6" I can't find any lift kits it has coil springs all the way around any help would be appreciated
01-03-2017, 02:03 PM | #2 |
Re: How can I lift my 68 2wd c10?
I have wanted to lift my 68 too.
I think this might be a way to go. http://67-72chevytrucks.com/vboard/s...d.php?t=447061
1968 GMC truck 910 Trim (Canadian) 127" WB 3 on the Three Trans (Saginaw SM330) 250 ci L6 Engine HEI ignition (early 80s L6) |
01-03-2017, 02:10 PM | #3 |
If I were you I wouldn't lift a 2wd truck it will just put more wear on parts and won't help much off-road if that's what you were going for.
'69 k10 |
01-03-2017, 02:23 PM | #4 |
I don't plan on going off road just don't wanna be like everyone else with a bagged or lowered Truck just thinking out of the box
01-03-2017, 03:03 PM | #5 |
Alright then, I just don't think there is any advantages to lifting a 2wd. I won't tell you what to do though.
'69 k10 |
01-03-2017, 03:39 PM | #6 |
Go Pack Go!
Successfully lifting a 2wd is possible, but may not be the safest to do. You end up changing steering angles that affect ride quality and safety.
You can order 2-3 inch body lift kits fairly cheep. You can also put 2-3 inch coil spring spacers on it. Don't go with the coil spring clamps as that is very unsafe. |
01-03-2017, 03:59 PM | #7 |
If you do raise it up, I suspect your driving experience would suffer.
A properly lifted 4x doesn't drive at all like a stock 2x truck, so expect yours to be even further away from 'normal' feel going down the road. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
01-03-2017, 04:53 PM | #8 | |
01-03-2017, 02:29 PM | #9 |
Keep it stock height and put some 31" tires on it.
1982 K10 SWB 1987 V20 - Sold - Doh! |
01-03-2017, 02:33 PM | #10 |
01-04-2017, 12:11 AM | #11 |
Not to hijack this tread, but I'd like to see pics of this!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
09-21-2018, 01:45 PM | #12 |
I found a killer deal on a 1972 Longhorn but to me a truck that long needs to be lifted not dropped. So we did a 4x4 conversion on it and gave her a 6" lift at first which i determined was to high for my tastes so we dropped it down to a 4" but if you want check out my build thread it will show whats all involved. Or let me know if you have questions.
Cheers!
- 1972 K20 Longhorn, 4wd conversion. "TAWNKAA" Project. 292ci Inline 6 / '93 NV4500 / 32 spline 205 TC / Dana 60s front & back / rear Detroit Locker / 4.10 Gears / 35" BFG MT KM2 / 4" Tuff Country lift. "TAWNKAA"Build Thread http://67-72chevytrucks.com/vboard/s....php?p=6823933 - 1970 C10 Lonbed, 292ci Inline 6, 3 on the tree, stock. |
09-21-2018, 02:15 PM | #13 |
The C20 Custom Campers came with like 31.7" tires stock. Factory tire size is 235/85R16 which is skinny and tall. I got a set of 265/75R16 on 7" rims and it looks better. Same height, but an inch wider.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
09-22-2018, 07:41 PM | #14 |
I wonder if chassis tech makes a lift spindle?
Im so sick of people talking crap about lifting a 2wd. Been reading it on forums for years. To each their own |
09-22-2018, 08:30 PM | #15 |
I've been wanting to lift my 68 C10 as well. I think they look cool sitting up high.
I just put some 255/70/15 tires on ralley wheels which helped slightly. I might put beefier springs in and see what that does. |
01-03-2017, 03:14 PM | #16 |
Moderator
Swap a 4wd chassis under it...seriously. With coils all the way around there really is no safe way to do it. The aftermarket does not support it with any specialty parts for our year trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
01-03-2017, 03:17 PM | #17 |
01-03-2017, 06:25 PM | #18 |
Bag it & ride fully puffed up?
01-03-2017, 06:27 PM | #19 |
doing a lift like that you are going to run into MAJOR steering issues that will be dangerous... it is like what alot of guys do with their jeeps they lift them then the steering is unpredictable and they end up crashing their truck...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847 Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210 |
01-03-2017, 06:27 PM | #20 |
They sell spacers for coils as most "leveling" kits for late models have spacers for the front.
01-03-2017, 07:09 PM | #21 |
All about them K’s
Your on the right track... sell that 2 wheel drive truck and buy a real truck! There's far less 4 wheel drive 67-72s than two wheel. So you'll accomplish standing out in the sea of dropped/bagged trucks.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
01-03-2017, 08:21 PM | #22 |
67 C30 3in blocks got rid of rag joint put in 2 universals, steers perfect. Go no higher than 3 in.
01-04-2017, 12:00 AM | #23 |
the boat guy
I've seen some wonky spindles used on ifs gassers. Looked like they removed the shaft out of one spindle then welded another spindle to the spindle attached to the ball joints like 8" lower.
You would be better off swapping to leafs and running an I beam in the front. The rear would need a custom panhard bar and panhard bar mount. A one piece driveshaft with a custom crossmember. There's a couple of guys with some long travel setups that look pretty sweet. |
09-23-2018, 05:45 PM | #24 |
there is a member here that built a off road trophy truck type machine. think it was a 67 with coils on all 4. he had a build thread to. hear is a link , maybe you will find some answers. scroll down a ways and you will see the truck. pretty cool
http://67-72chevytrucks.com/vboard/s...d.php?t=203445 |
12-29-2024, 08:33 PM | #25 |
You might look for a C20, and use the suspension from the 20. Just thinking of my C20, and betting it sits a couple inches higher than a C10, although I have not measured. Remember, a standard C20 came with coils all around, but could have been ordered with leaf rear. I see quite a few C20's for sale, as they were left up until the last few years. I purchased one about 5 years ago as it was a big block truck, and my intent was to put 1/2 ton suspension on it and basically convert it, but after a while decided to stay with what it had. Downside was a little rougher ride, and very difficult to locate a decent set of wheels. I finally decided on a set of Accuride wheels, factory hub caps and some passenger rated tires that are 16's.
