Old 01-04-2017, 07:32 PM   #1
KyleSeal
KyleSeal's Avatar
I'm out of whack somewhere... but where?
New body mounts (energy suspension poly's) and I kept the original shims in place with new washers, but the cab seems to be high on the driver side, and the control arms seem to sit at different angles.... any way to adjust?
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 01-04-2017, 07:33 PM   #2
KyleSeal
KyleSeal's Avatar
Re: I'm out of whack somewhere... but where?
First photo is passenger side arm and second is driver
Old 01-04-2017, 07:35 PM   #3
KyleSeal
KyleSeal's Avatar
These arms seem to be at different angles...
Old 01-04-2017, 07:51 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Sounds like one of your front coil springs may be weak and sagging....
LockDoc
Leon
Old 01-04-2017, 08:01 PM   #5
KyleSeal
KyleSeal's Avatar
LockDoc
Which is strange cause they're brand new, with barley 100 miles on them.
Old 01-04-2017, 08:17 PM   #6
LockDoc
LockDoc's Avatar
If you have a flat concrete floor measure both frame rails in the front, center, and rear of the truck and see what you come up with....
LockDoc
Leon
Old 01-04-2017, 08:10 PM   #7
demian5
demian5's Avatar
Looks like you need to do more research and measuring to see if and what is bent or installed incorrectly.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-04-2017, 08:46 PM   #8
KyleSeal
KyleSeal's Avatar
I did notice however that my springs (when truck is jacked and no weight on suspension) my drivers spring I can move with my hand and passenger is movable but much tougher to move/wiggle. They're 3 inch CPP drop springs.
Old 01-04-2017, 08:54 PM   #9
weq92f
weq92f's Avatar
Make sure the springs are seated properly into the notch in the lower control arm?
On a 68 1/2 ton, leaving one out of the notch caused that side to ride higher by about an inch.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
alignment, body mounts, cab
