01-05-2017, 01:53 PM | #1 |
70+ ( Old Skool Club )
Truck on EBay Factory A/C Question
I saw this truck this morning on EBay and its really cool . Looking at the pics I see the owner has redone the interior very nicely and all the options on the Spid appear to be on the truck. The seller says it has factory A/C which from the under hood and the cab vent pics shows it seems to be a factory installed A/C system. My question is, if the A/C is factory why isn't it on the spid? Any ideas anyone?
http://www.ebay.com/itm/1971-GMC-Sie...E:B:SS:CA:1120
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-05-2017, 03:06 PM | #2 |
Re: Truck on EBay Factory A/C Question
It appears to be factory , the glove box door is a different color than the rest of the truck , I believe it should be the same color as the dash , nice truck
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
01-05-2017, 03:23 PM | #3 |
GMC glove box doors usually were the same color as the dash surrounds and with being a base truck and with the interior work done on this truck you can see the glove box door (which was probably black to start with ) was repainted to match the new dash bezel. The GMC Z62 CST and Sierra Package trucks had the gauge surround and glove box door pained like the main interior color.
01-05-2017, 03:56 PM | #4 | |
Old member
Back then what people say where factory installed was a dealer installed one. If you had the money you could of had that installed after you bought the truck. People where not as picky about those type of things like we are today.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-05-2017, 04:38 PM | #5 |
I also noticed after looking again , it appears that one spid has been glued on top of another , look in the lower left corner of the spid picture , that in no way would sway me from this truck if I was interested
01-05-2017, 04:52 PM | #6 | |
My best guess is that the glovebox door is from a different truck, but I don't really know.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
01-05-2017, 06:04 PM | #7 |
the SPID looks right to me, just has a corner peeling up. I added factory ac to my '71 K/10 back in 1991, and to look at it today it just looks like an old truck with factory ac. It must have just been added some time along the way.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
01-05-2017, 06:10 PM | #8 |
A/C should be on the spid, different door? different spid? 4x4 vacuum reservoirs sit on an offset bracket, bracket is missing. Also, if you look under the vacuum reservoir, there is a strip of black tape - box is cracked. On the blend door lever (in engine bay) I can't see a cable to it (might be there, I just can't see it) It's possible the A/C was added.
I wouldn't let any of these issues keep me from buying it as long as the bid doesn't go too high. |
01-05-2017, 06:13 PM | #9 |
I've seen a number of threads here on the board where folks say they want to add a "factory A/C" to their truck. We tend to use the term to distinguish between the factory system and a newer aftermarket system like Vintage Air, not so much that it was put in from the factory. The seller could have added a "factory A/C" to the truck that didn't originally have A/C.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
01-05-2017, 06:13 PM | #10 |
It has Ac, who cares when? I think that WINCH is worth comenting on though! WOW
01-05-2017, 07:40 PM | #11 |
MY 72 C10 has a tilt column but it is not listed on my SPID.
A dealership or mechanic may have added a correct tilt for a previous owner at a later time. Curious, is there a possibilty that some options were not updated and might have been inadvertantly omitted on the original SPID's from the factory? I wonder if anyone else may have factory options on their trucks not listed on the glove box SPID? That trucks A/C system looks to be correct. |
01-05-2017, 08:18 PM | #12 |
Old member
I can tell you Yes you could of had the factory AC added to the truck for the right amount of money at the dealership.
My dad worked for GM and drove several of these model trucks and yes he had the factory AC added to a couple of them for customers. Not everyone would spend the money to have it done, they would have the cheaper under dash unit installed but you could have the 4 season installed if that's what you wanted. These trucks are 40 years old and you can make a spid to match your truck so is it are isn't it doesn't matter in the long run. You only have the PO word on what the vehicle is unless he has complete documentation and even then it's not always 100%. I don't know about all of you but it is harder for me to believe some one bought a truck in 1967 and it changed hands several times over the years and nothing was taken off of it are added to it. It's a nice truck so go for it if it's what you want.
01-05-2017, 08:08 PM | #13 | |
Also, another quick note: Check out how it's mounted to the front of the bumper!
White K20 |
01-05-2017, 09:10 PM | #14 | |
01-05-2017, 08:39 PM | #15 |
That interior paint scheme matches my 69 GMC truck. The glove box matches the gauge cluster and the door panels.
Can't comment on the AC, except to note that it is my understanding that the firewalls are different on AC and non-AC trucks. So how did the dealerships add "factory" AC?
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
01-05-2017, 08:49 PM | #16 | |
As for whether or not a/c was factory installed or not, probably doesn't matter much, but I do think the answer would appear if the firewall were examined underneath. Not that I'm gonna buy it just to find out though. Greg, my assumption would have been that it would be on the SPID, so either it's a missed SPID RPO for an "at the factory" install or it's somehow installed as an afterthought by a dealer or po. But, bottom line, I think the gb door has been painted (if the SPID VIN matches the truck VIN) or replaced (if the VINs don't match - which I doubt is the case because the SPID, which isn't a repop, sure describes this truck to a t, except for the a/c). Seller lists a VIN that matches the SPID, but who knows what the metal tag says... I'd sure want to verify they match if I were interested. It is a nice truck and the a/c wouldn't deter me from buying it if I were interested. Agree, the winch is coo! Last edited by jocko; 01-05-2017 at 08:55 PM. |
01-05-2017, 10:20 PM | #17 | |
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
01-05-2017, 10:43 PM | #18 |
71-72's (probably 69-70 also) on GMC's, the glove box door has always been painted (gloss) the interior color along with the gauge bezel face. That black glove box door looks correct and original to me.
01-05-2017, 11:27 PM | #19 |
trucks72
Someone has added air to that truck. It is hard to see in the picture but there is a hole where either wires or the blend door cable is coming out. That hole is not in the correct spot. On a non air ruck that hole is there. If you take a heater housing off and put a air housing up to it, that hole will show. Not all the hole but about half of it. I have installed a lot of air on trucks. That is the only why you can tell if someone has done that.
01-05-2017, 09:42 PM | #20 | |
Old member
01-06-2017, 02:00 PM | #21 | |
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-05-2017, 10:16 PM | #22 |
Carpe manana
Factory AC from a different truck. That's a nice gmc.
01-06-2017, 02:09 PM | #23 |
Member #1049
I agree with Pete, To me it looks to have factory AC installed which was taken from another truck.
It does not have the factory 4X4 vacuum pod angle bracket, plus if you look closely at the picture that shows the engine compartment you will notice that the hole in the firewall for the AC/Heat cable does not come through in the factory location. |
01-05-2017, 11:55 PM | #24 |
arent those Factory a/c outlets on boths side of the dash??? the dealer wont install those ?? rite!!
01-06-2017, 12:26 PM | #25 | |
Even if that's not the case, we don't have an uninterrupted history of this truck since Day 0, so someone else could have done it at some point in its life beside the dealer too.
