01-07-2017, 03:22 AM | #1 |
1987 gmc jimmy dally driver build
Hi guys. I have a 87 gmc jimmy that I'm building for my DD and it has a lot of problems that need fixed and I've already started started the build.
Posted via Mobile Device |
01-07-2017, 03:24 AM | #2 |
01-15-2017, 02:09 AM | #3 |
Re: 1987 gmc jimmy dally driver build
The work on the jimmy has been slow ordered a lot of parts. Ball joints tie rods all bearings and seals and brakes.so while I am waiting for the front end parts to get here i did the rear end brakes and the rear brake where bad.
01-15-2017, 02:11 AM | #4 |
This is the passenger side.
01-15-2017, 09:38 AM | #5 |
I hope you pulled the rear axles and replaced the seals. It appears as though both were leaking quite a bit.
Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
01-18-2017, 07:43 PM | #6 |
So finally got my ball joints today.now to install them.
01-18-2017, 07:59 PM | #7 |
So for anybody wondering what I have done to the truck as of now here's the list. Front end.
Ball joints U joints Spindle bearings and seals All four tie rods moog New rotors pads calipers and hoses Hub bearings and races and wheel seals New steering stabilizer And the steering disk at the box rear end Drums shoes wheel cylinders rear hose And all the hardware.and that's just a part of it the 700 needs a rebuild and the case is leaking. |
01-19-2017, 01:53 PM | #8 |
That's a good start. Take care of all of the safety/drive-ability stuff then you can start on the fun stuff.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
01-21-2017, 09:06 PM | #9 |
So Here's an update on my jimmy had a major set back today.the new ball joints where pressed in at a local shop and got some bad news.The passager side knuckle top ball joint had mushroomed by someone before me trying to remove it and when pressed out it wiped out the top bail joint hole.so now the bail joint can be fully seated and you can turn the knuckle upside down it will fail out.so now I'm stuck trying to find a new front axle.
02-06-2017, 10:18 PM | #10 |
So after a week of looking found a good set of knuckles.so that's one good thing.so today but instead of working on the front end I decided work on ac in the truck. it was 72 today.i had fixed the ac in October it worked good but all the air was going to the floor I now no why my plastic tab was broken so I made my own today.
02-06-2017, 10:37 PM | #11 |
Then I did a little engine work with fresh oil and filter.new spark plugs new antifreeze tstat and temp sender.but the best thing I did was a new carb a used qjet that I built myself.the truck was a tbi motor that for some reason the po did a carb conversation using a crappy Holley 650 that leaked more gas than it burned.i fixed it but then it never ran as good as it does now.so got tired of the Holley so I rebuilt a qjet.Got it tuned and it runs so much better than Holley ever did.
02-18-2017, 02:24 AM | #12 |
So after a few weeks of rebuilding the front end I moved on to the rear.and not so good pulled the diff cover and found some pieces of the locking assembly.its a 10 bolt g80 gov lock I got lucky and there was no damage to the carrier so I converted it to open diff before it did it for me.
02-18-2017, 02:26 AM | #13 |
After converting it.
02-22-2017, 11:02 PM | #14 |
Looks like you got all the hard stuff done. I am hoping to get started on my project soon.
02-27-2017, 06:04 PM | #15 |
02-27-2017, 06:08 PM | #16 |
Don't have much to do on the jimmy right now so messed around with the wheels and cleaned them up as best as I can.
02-27-2017, 09:03 PM | #17 |
Looks good!
02-28-2017, 03:53 AM | #18 |
Nice work that's a good looking truck.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
03-05-2017, 09:28 PM | #19 |
03-05-2017, 09:32 PM | #20 |
So after a week of driving the jimmy around got tired of the steering wheel not locking in place so this weekend I tore down the column and found this.
03-05-2017, 10:14 PM | #21 |
Those 4 bolts holding the tilt bracket should be unscrewed individually and put some thread locker and tighten them back up. Since your already there. But your probably way down the road by now.
03-05-2017, 11:07 PM | #22 |
bigjim321.thanks.but if you look at the top of the tilt housing its broken a cross the top where the tilt mechanism locks to.
03-06-2017, 10:08 AM | #23 |
I use a 90 jimmy as my daily driver. Has the same wheels you do. I sprayed some aircraft paint stripper on them. Peeled the clear coat. Then was able to get a better polished shine out of them.
03-06-2017, 11:23 AM | #24 |
B[QUOTE=blakerj10;7877798]I use a 90 jimmy as my daily driver. Has the same wheels you do. I sprayed some aircraft paint stripper on them. Peeled the clear coat. Then was able to get a better polished shine out of them.[/QUOTE never thought of aircraft stripper before.but I'm not keeping these wheels.Im looking for some rally's to go on.it I might try it on them when I find some.
03-09-2017, 06:03 PM | #25 |
So after a few days of messing with the steering column had to order some parts for it so can't drive it for a few days.so out came the c10.its Been parked for 2 months in my shop and I almost forgot it's was in there.
