Old 01-09-2017, 04:41 PM   #1
FNBasham
Short bed conversion
So I was looking to cut my truck down I know 20 inches needs to be removed does anybody have a good diagram of where to cut and what else needs to be changed besides fuel an brake lines and the driveshaft
Oh and on an other note if anybody knows where to get a shortbed stepside bed that will fit a 74 c10 please hit me up
FNBasham is offline   Reply With Quote
Old 01-09-2017, 05:02 PM   #2
daddyjeep
daddyjeep's Avatar
Re: Short bed conversion
14" between the front two bed mounting holes. How you cut is a common argument, but I went with a 45 degree cut myself. There really isn't a precise measurement from the front hole or back hole, just remove the 14" between them. The e-brake cable will need changed or modified and the gas tank will need to be changed. Either a short bed tank needs swapped in or as many do, a blazer tank can be installed.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 01-09-2017, 05:10 PM   #3
FNBasham
So how much do you cut off the back
Old 01-09-2017, 07:44 PM   #4
daddyjeep
daddyjeep's Avatar
That seems to vary a bit. I cut about 3", but I haven't cut down my bed yet so it might not be right.
04 1500 crew cab
Old 01-09-2017, 08:37 PM   #5
cochino12
It followed me home?
cochino12's Avatar
I've done three of these conversions and I've always cut about 3" off the back, I left as much frame there as possible to have room for bumper brackets.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-09-2017, 08:42 PM   #6
FNBasham
So besides cutting and welding does anything else need to be removed and do I need to attach a new bed mounting point?
Also where did you get the shortbeds from you put on the swaps
Old 01-09-2017, 09:43 PM   #7
daddyjeep
daddyjeep's Avatar
The bed bolts to the frame so...no, no new mounting points. I cut my bed down to a short bed. That is not the best route though. Find a used bed or buy all the parts from LMC to build a new one.
04 1500 crew cab
Old 01-09-2017, 09:47 PM   #8
cochino12
cochino12's Avatar
There is also a rear crossmember that can be moved forward. The holes were already drilled in the 1/2 ton I did but you'll need to drill them if you are working on a crew cab.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-10-2017, 10:59 AM   #9
SCOTI
SCOTI's Avatar
Shortening brake lines & re-routing or shortening electrical.
SWB specific gas tanks or aftermarket swap.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 01-10-2017, 11:14 AM   #10
moregrip
moregrip's Avatar
great info, I'm in for this mod to my LB as well! Post up pics if you can when you start the project brother!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 01-10-2017, 07:07 PM   #11
SkinnyG
SkinnyG's Avatar
You could give a look through my shortened bed write up:
http://www.gwellwood.com/project-car...ing-the-frame/
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is online now   Reply With Quote
