Old 01-12-2017, 09:41 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Photos of your zinc plated or black phosphate hardware and such on your truck
I'm pondering black phosphate coating Vs black zinc plating - for nuts, screws and bolts to hood hinges.
For appearances, I may like the phosphate better. I believe it was factory, for most pieces anyway. From what I've read, they use magnesium to blacken it. I believe it should be oiled,lacquered or waxed. Can't say if that's part of a phosphate service.
Not that I need it, but zinc provides more better resistance to the elements. The bonus of zinc is I can have it done locally, and I'm A LITTLE nervous about sending this stuff out for phosphate. I'd assume take a road trip then mail it.
At any rate, I've seen the results of both off the truck. Pics. of these or other finishes on your trucks welcome and appreciated.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-12-2017, 10:01 PM   #2
71CHEVYSHORTBED402
Re: Photos of your zinc plated or black phosphate hardware and such on your truck
Breaking my own "rules".......Here's a comparison of the two finishes.
Tony
Old 01-13-2017, 12:16 PM   #3
Jason Banks
Jason Banks's Avatar
I am about to have a bunch of mine done in Black Zinc. At work I have some things done in Black Zinc and prefer it to any other black finish.
Jason Banks is online now   Reply With Quote
Old 01-13-2017, 12:25 PM   #4
suville
suville's Avatar
Check out lauerweaponry.com lots of good products there that lend themselves to automotive application
suville is offline   Reply With Quote
Old 01-13-2017, 12:50 PM   #5
Classic v6 GMC's
Classic v6 GMC's's Avatar
I would do the black zinc.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 01-13-2017, 08:35 PM   #6
71CHEVYSHORTBED402
Interesting. I wonder how durability compares with the industrial process?
Tony
Old 01-13-2017, 08:39 PM   #7
71CHEVYSHORTBED402
Can't tell for sure, but for the black zinc fans, the sheen appears satin to me. GM's undercarriage was satin. Perhaps the core support as well.
Tony
Old 01-13-2017, 09:23 PM   #8
James the III
What one holds off rust longer?
James the III is offline   Reply With Quote
Old 01-13-2017, 10:17 PM   #9
71CHEVYSHORTBED402
Zinc.
Zinc plating comes in all kinds of colors. One is "clear", though I'm not sure clear is really clear. From what I gather it's the common unpainted metal color.
The "receptionist" said in her experience most people have restoration parts done in clear, and nobody had run with black. But she likes the idea a lot. Apparently mods / restores run in the family.
Here's a link to the place. They anodize as well............Hello outer grille. http://apexanodizing.com/service-det...c-plating.html
Tony
Old 01-14-2017, 12:15 AM   #10
sduckworth13
sduckworth13's Avatar
Here is post #265 from Vic1947 build thread. http://67-72chevytrucks.com/vboard/s...nc#post6246012
"As you probably know, very few coatings stand up to Mother Nature over time. I've had better luck with cad plating than zinc, so I specified yellow cad for this batch. I have several buckets of hardware that I had done at Del's Plating in Houston in the 80's that still look pretty good. The coatings (some zinc, some cad) have dulled a little, but no rust. However, when you put the fasteners into service, typically the corners where the wrench makes contact is where the problems start. Putting them thru several cycles of assembly and disassembly will quickly remove the sacrificial coating at the pinch points and cause the onset of oxidation. My expectation is 3-5 years of service for these fasteners. If I were to drive the truck on salted roads in winter, I'd be lucky to get 1-2 years. You shouldn't have that problem in El Campo. "
"Not all plating companies are created equal so you can't assume their process will give great results if you take them junk. I spent a lot of time prepping the fasteners by first soaking them in muriatic acid then neutralizing the acidic reaction with a baking soda and warm water rinse. After thoroughly drying them, I cleaned the remaining light surface rust in a glass bead cabinet. Doing this gave me the best shot at a nice finish. Just remember GIGO (garbage in, garbage out). One last thing about cadmium. Most plating companies have small tanks that won't accept really large items. For the big stuff you'll have to live with zinc. Both coatings are available in clear (silver) and yellow. However yellow cad has a very pleasing variegated finish with red and green highlights which is another reason I prefer it."
Scott
sduckworth13 is offline   Reply With Quote
Old 01-14-2017, 12:32 AM   #11
71CHEVYSHORTBED402
That's real informative. I've got the prep part covered using white vinegar, a soak in WD-40 and lots of brushing. They come out nice. He makes a good point about parts in service, but wouldn't you have the same issue with the original parts from factory?
Tony
Old 01-14-2017, 01:07 AM   #12
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
I've done some of this on one of my Camaros.
Over time moisture in the air seems to affect the finish.
Have to check some of mine to offer you what I'm experiencing.
Mine was done over 20 years ago.
I'll post something as soon as I can
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
