Old 01-15-2017, 11:59 AM   #1
northern 85
northern 85's Avatar
Good fitting black carpet???
Going to buy new black carpet for the 66, any advice on what to buy or not to buy?? Thanks its a 66 factory auto that will have 67/68 buddy buckets.
northern 85 is offline   Reply With Quote
Old 01-15-2017, 12:14 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Good fitting black carpet???
Many retailers sell the carpet kits which are all made by the same manufacter. Mostly, it's a matter of finding your best deal. I got mine thru Rock Auto, and I went for the "mass backed" option which is a heavier plastic on the floor side of the carpet.
It wasn't a perfect fit, but it was pretty close. (Maybe it was the installer). Another tip I have is using a cheapie electric woodburner or soldering iron to make the holes for your seats and etc.
AcampoDave is offline   Reply With Quote
Old 01-15-2017, 04:09 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
The Auto Custom Carpet sets fit better than the knock off ones I've installed in the past. I also use my soldering iron (knife tip) to cut the holes for the seat bolts, etc.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-15-2017, 04:16 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Would that be these guys?: https://www.accmats.com/
Old 01-15-2017, 05:05 PM   #5
vin63
vin63's Avatar
Yes, the last couple I purchased through Stock Interiors.
Old 01-15-2017, 05:56 PM   #6
'63GENIII
'63GENIII's Avatar
Just used Stock Interiors for the black carpet in my '63 - high hump. I too got the thicker mass backing. I also got the piece for where the gas tank used to be. Fast shipping. Overall Im very happy with the fit and noise reduction. X3 on the hot iron. I used an icepick and propane torch from under the truck.
Worked great. Id use them again.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 01-16-2017, 02:59 AM   #7
Kenfuzed
Kenfuzed's Avatar
I personally would recommend against using TrimParts molded carpet. Perhaps others have had better experiences but mine was not good. Here is more about my carpet and experience with this company.
http://67-72chevytrucks.com/vboard/s...d.php?t=724803
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 01-16-2017, 07:43 PM   #8
northern 85
Great info guys! Thanks, nice work Vin63!!
