01-15-2017, 03:11 PM | #1 |
Short Bed Side measurements
Hey everyone, I'm working on my '70 fleet side long to short bed conversion. I'm at the point where I need to cut the bedsides down and I can find the overall dimensions (78 1/4"), but I was curious if anyone had a detailed diagram of the measurements of the bed sides. More specifically, I'm looking for the length from the front edge to the start of the wheel well and the measurement from the rear portion of the wheel well to the back edge.
Thank you in advance
----------------------------------------- 1970 C10 - SWB (Converted) 2011 Silverado 1500 Ext. Cab |
01-15-2017, 03:22 PM | #2 |
Re: Short Bed Side measurements
You don't necessarily need those dimensions, what you need is how much to remove which is 12" in the front section and 7 7/8 or 8" in the rear section. I don't know the exact on the rear because I have always used short bedsides when making a short bed from a long bed.
01-15-2017, 03:25 PM | #3 |
That's what I was hoping the answer would be. I'm assuming cutting between the two cross braces is going to be the way to go.
Thank you
01-15-2017, 03:37 PM | #4 | |
1. disassemble complete bed to sides, floor and front panel. 2. Shorten floor 3. shorten sides, shorten on bench. 4. Reassemble the bed There is a good thread here about a guy that shortened the floor by taking out the rear floor crossmember and cutting the floor and then re-installing the rear crossmember, saves a lot of cutting and welding, he reshaped the cut edge to "resemble" the factory one. Here is the thread....http://67-72chevytrucks.com/vboard/s...d.php?t=667694 On the front he just cut it straight across and put the bolt in the low parts of the floor which also saved a lot of cutting and welding....I think if I was going to do one that I would do it that way, the end result looked good especially when you consider the cutting, welding and grinding time he saved. |
01-16-2017, 10:33 AM | #5 | |
01-16-2017, 10:53 AM | #6 |
I know your question has mostly been answered already, but there are many other threads that document shortbed conversions as well. I really like 65standard's technique too, but as you pointed out already, it does take a fair bit more metal working skills. I responded to a post very similar to this a while back and provided links to several of the best documented conversion threads. You can find that post here. Hope that gives you some ideas.
Builds: Green Gus the 68 C10 ; Bluey the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
Tags |
cutting bedsides, long bed to short bed, swb fleet side |
