Stock height or small lift 4x4s tire size and lift
I have a 1981 stock longbed with negative front springs, is that normal or are they just extremely worn? I would like to put 33x12.50x15 tires on it with little to no lift, I'm going for the beefy, but stock look. Let me see some picks of your trucks and give info about lift and tire size! and brand of lift and how it rides please. Pic of my truck below
Re: Stock height or small lift 4x4s tire size and lift
My 80 k10 Has 33/12.5/15s on it. I have a 2" rough country lift on it, it rides better than it did with old worn out springs, and old worn out shocks on it.
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
![]() Join Date: Mar 2003
33s will not fit on the front with stock negative springs. They will be real tight on the rear also. 31s will fit on the front----barely. You could put a 3 leaf pack on the front and it will pick it up about 1-1/2-2''. Then you could put a 2'' block on the rear. I'm working through the logistics of this on my 91 suburban at the moment
Your truck looks great! Thats about exactly what I'm looking for, Does that have blocks in the rear or springs?
Thanks man. Yes it has blocks in rear.
Jayson, when you installed the 2 inch Rough Country lift how much did it actually lift your truck? Was it 2 inches? Or a little more or little less? Thanks
Depends on offset of wheels. Buddy has mid 80s that is all stock and is running 33s on 8" rally's. Its close but fits/clears. Normally at least a 2" lift is enough to clear.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Um....It says the actual tire size above the pic.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
Yep. One can't really provide much more detailed info than what was posted.
You shouldn't have any issues running 33's without a lift, that's what I ran on my '78 K5. Here's a picture of my current project:
![]() It's an '84 diesel K5 with 275/70R18 tires which are 33.2" according to the manufacturer's website. The truck is otherwise completely stock and I haven't had any signs of rubbing. |
Nice trucks guys!
Cochino12, if mine were a 3/4 ton, that is the wheels I'd have on it, the rallies and your factory alum wheels you have are the best looking wheels going.
#15 |
driving is in my blood
I'm a lowered guy, but I feel this guy gets it.
https://www.youtube.com/watch?v=r85zDhRpRTU
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
Tags |
2 inch lift, 33s, 4x4 |
