Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 01-20-2017, 10:42 AM   #1
GMCNUT
GMCNUT's Avatar
WTB: 1963 specific factory power brakes
In 1963, Chevrolet and GMC began moving away from the Chevrolet Hydrovac and GMC Midland inner-fender mounted power brakes used from 1955 thru 1962, to the first firewall mounted system which had vertical booster brackets attached to a special flat steel spacer (see photos). In late 1963, GM went to a newer power brake design that allowed better air cleaner and engine area clearance which employed the use of the common "wedge" shaped aluminum spacer and horizontal mounting brackets you generally see on all 64-66 trucks. So only the earliest of 1963 trucks would have come with the original design w/ flat non-wedge shaped firewall spacer you see below. Most often found on 1 ton trucks, but available on 1/2 and 3/4 ton 1963 models.
If any of you have one or know where one is, or have accidentally bought a setup off a 1963 that you are intending to install on your 64-66 project I am perfectly willing to trade you the correct one for your truck in order to get one of these early 63 setups. Let me know what you have?
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 01-20-2017, 01:27 PM   #2
Brad54
Brad54's Avatar
Re: WTB: 1963 specific factory power brakes
Are you looking for just the steel plate?
If that's all, you could easily make one or have one made.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 01-20-2017, 02:14 PM   #3
GMCNUT
GMCNUT's Avatar
-Brad
yes, but you'd need an original to use as a template - there is a flange to the center hole to retain the rubber, and the precise alignment of the holes is important etc - I wouldn't want to guess at it
Old 01-20-2017, 02:16 PM   #4
GMCNUT
GMCNUT's Avatar
I bet Captain Fab could make one in less than 10 seconds if he had an original to go by
