Old 10-14-2003, 06:04 PM   #1
68 Suburban
68 Suburban's Avatar
Timing Dilemma
My truck likes the timing advanced far enough that the truck hesitates when starting. If I retard it so the truck starts easy, it does not run nearly as well. What I do is keep the timing advance and keep the kill switch off to the HEI until I start spinning the starter, then I hit the kill switch and it fires right up. Any other suggestions?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 10-14-2003, 06:28 PM   #2
RON WOODGEARD
Resident Young Old Dude !
The only time I have encountered that was,
#1 my starter brushes were going bad, or something else in the starter.
#2 my timing chain had slipped a tooth.
Did it slip, or did I screw up on the install ???????
Ron
RON WOODGEARD is offline   Reply With Quote
Old 10-14-2003, 06:30 PM   #3
68 Suburban
Well it is a brand new starter... And the old one did the same thing! lol
Old 10-14-2003, 06:37 PM   #4
RON WOODGEARD
Ouch !! Well,,, Do you have a couple of free extra hours ???!!
Ron
Old 10-14-2003, 06:39 PM   #5
68 Suburban
It has been like this since I got the engine new. That was 3 years ago. I guess i will leave it alone.
Old 10-14-2003, 07:44 PM   #6
JimKshortstep4x4
Talking
What size are your battery cables and what is the cranking capacity of your battery?
You could be loosing cranking capacity if the cables or battery are undersized.
Jim
Old 10-14-2003, 07:54 PM   #7
68 Suburban
Well, when I did change that starter, I thought the possitive cable going down to the starter was skinny . Maybe that is it?
Old 10-14-2003, 08:17 PM   #8
crazy longhorn
Fabricate till you "puke"
I agree, I would look at the battery & cables 1st.....if that doesnt get it, you might think about cutting back the initial timing, & getting a little more mechanical timing, or upping the vac advance to help the situation. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-14-2003, 08:21 PM   #9
cableguy0
i agree either run more mechanical or keep it how it is and get a high torque mini starter otherwise its gonna crank slow
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-14-2003, 09:39 PM   #10
RON WOODGEARD
Are you running an engine ground strap ??
If not, give that the first try.. .
Replace your battery cables with good sized ones, and do a engine to frame ground strap.
Ron
Old 10-14-2003, 09:45 PM   #11
68 Suburban
Ron
I do have the ground straps on both sides of the engine. Thanks for the ideas
Old 10-14-2003, 10:56 PM   #12
Hooter
My other Love
Hooter's Avatar
um what do you have running for compression on the starter, and what kind of cam are you running in there? if you have done any radical mods, i would try retarding the cam a tooth, butthen again that would be the very last thing id want to do
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 10-21-2003, 06:30 AM   #13
68 Suburban
I guess the problem was the skinny starter cable. I put a new 4 guage wire on, and it seems to start fine. I never had the problem with the old starter. I guess this one call for more power.
Old 10-21-2003, 07:24 AM   #14
tom hand
CCRider
tom hand's Avatar
Even though the bigger cable makes it start better, you still have a problem that will shorten starter life. I would look at getting the HEI recurved so it runs correctly without running so much initial advance...that will be the true fix.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 10-21-2003, 09:41 AM   #15
Blue Beard
Blue Beard's Avatar
We use to make battery cables out of the cable we used for welders........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-23-2003, 05:48 AM   #16
68 Suburban
I found out the problem.... The brand new starter was drawing over 200 amps!!! Not good.....lol
Old 10-23-2003, 08:48 PM   #17
Blue Beard
Blue Beard's Avatar
Whats that strarter for a drag engine....?
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 10-23-2003, 09:37 PM   #18
ddsmith
Glowing since 1978
ddsmith's Avatar
Hey 68 Suburban,
How did you tell "The brand new starter was drawing over 200 amps!!! " Did you take it somewhere to check it or did you use a clamp on DC ammeter. I have a DC clamp on ammeter and I guess that is something it would be very useful for determining.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 10-24-2003, 12:49 AM   #19
68 Suburban
Being the cheap ass that I am, I bought the cheapest starter Checker had. It cost me all of $31. I even talked them into giving me a lifetime guarantee, instead of the 3 year guarantee. The whole time I had it on, it would turn over a lot slower than my old starter. Then when the engine would warm up, it really dragged. Being the lazy ass that I am, I put off taking it out and returning it. Well last night, I got stuck somewhere while the starter cooled off enough to start the vehicle. I went to the closes Checker and told them what was going on. They told me I had to take it off so they could test it. Now I might be a Lazy and Cheap ass, but I am not a dumb ass :p , I went home took it off and took it to the 24 hour Checkers (11pm). They tested it and said, yes it is bad. They did not have the same starter in stock, so the manager upgraded me to the Autolite starter ($56), for free! This thing you tap the key and it fires right up. I think I have learned my lesson about being a cheap ass on something like this
Old 10-24-2003, 01:22 AM   #20
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You'd think so...but you'd be suprised.
I went through pretty much the same deal once...and I have a cheapie one on there now.
