question about welding bedsides
When I took apart the bed of my 66 fleetside, each bedside was welded to the rear cross member in two places. I was planning of re-welding everything in the same way when I put the bed back together. But now that I am putting it together, all nice and shiny, I am questioning whether or not it is necessary to re-weld. Anybody have any experience with leaving off these welds? Does it comprimise the stability of the bed?
Any recommendations to weld or not? Thanks Last edited by Metalaroundstone; 01-24-2017 at 11:06 AM. Reason: missing facy |
Re: question about welding bedsides
My '60 did not have the bed sides welded to the cross members at all.
B |
I didn't re-weld mine. you can keep an eye on the bolts so they don't loosen up. Should be fine.
1961 chevy K10 my build is------------61K10 build |
![]() Join Date: Aug 2010
It's my understanding that GMC's did not come welded. That's a chevy thing. So I'm guessing it would not be a problem leaving it alone.
![]() ![]() Join Date: Apr 2012
Chevy did this before the bed was painted. All Chevy beds were painted as an assembly. Most GMCs were, parts painted individually in finished color, then assembled . Ive done several this way freshly painted , no welds , you will be fine doing it that way. Tailgate needs to be installed before you finish tightening all the bolts for rear alignment of the bedsides.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
Thanks for the replies. Very helpful. I will see how it goes without the welds. I can always weld it later if it is not strong enough.
