speaker suggestion/recomendations
hi all, I have my stock radio boxed and ready to ship to gary tayman for the fm conversion so I need to start thinking on speaker options. i'm thinking either the kick panel version or under seat boxes. has anyone compared the 2 and which did ya like better as far as sound quality? I still have an in cab tank and plan on keepin it so behind the seat is not an option. if I do the kick panel i'm going to go with the upgraded pioneer option. so let me know what you think and what kind( brand/model) you went with. I have never heard an under the seat speaker so I have ne idea what to expect from that version. going in a '71 c10..
thanks keith
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Re: speaker suggestion/recomendations
I had the under seat 6x9 boxes..
If you have a choice I'd do the kick panels.. and the under seat boxes.. but if only one, the kick panels.. the underseat the mids and highs fire straight on the seat and get muffled.. unlike the lows that don't care.. |
I USED to have under the seat speakers, but the sound was never a good quality compared to the kick panel speakers. It always sounded muffled when they were under the seats. If that makes sense.
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
#4 | |
On my 64ss I made a bracket and mount to put infinity's in the stock hole in the dash, They sound great. Maybe what I'm missing is that in the truck.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Think I'm going to use Retrosound in-dash unit... It has 5 RCA outs (Front and Rear Left and Right + sub)... I've moved the tank, and am building a custom box that replaces the tank and wraps around the rear corners. I am running 2 12 inch Kicker shallow mount subs, Polk 6 1/2 two ways in kick panels, Polk 5 1/2 in the corners of the box behind the seats, and two amps. Additionally, am putting the Retrosound shallow mount 2 channel speaker in the factory dash opening, and running it off of high level front outputs from the radio... The Kicker sub amp is 600 watts x 1 @ 4 ohms, and Kicker 4 channel 100 watt per channel @ 4 ohm for the other speakers.
Is this overkill for a 60 year old guy who like classic rock music??? |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
I don't think so..
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#7 | |
![]() Join Date: May 2012
White K20 |
Here's a couple pics, nothing fancy. Plus the speakers are about 30 Years old, and they still kick fine.
Attachment 1615330 Attachment 1615331[/QUOTE] Thanks for the pix... Good to know you're having good luck with the Retrosound unit. I need to figure out a build thread and post pictures when I get this going better. I will post somewhere... Thanks again!! |
#10 | |
![]() Join Date: May 2013
Whats "overkill" ![]() My 67 has a 600 watt amp pushing 1 jl 10 behind the passenger bucket , and 2 boston acoustics 6x9s in a center console I made , the head unit pushes 2 6 inch coaxils in the kickpannels , and 2 4 inch coaxils where the stock speakers were , I also run 2 1 inch tweets off of the front channel they take almost no power to run .
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive Last edited by 67 chevelle; 01-27-2017 at 09:48 AM. |
#11 | |
I plan on speakers in the kick panels, rear corner behind seat, and the stock location. With at least 1 to 2 subs and amps to match. Ive got a long time to figure out the specifics on mine though. |
Like the other guys mentioned, the highs get muffled significantly by the seat. I'd think kick panel speakers would be the best option. I have speakers behind the bench and I have to cut the bass frequency and boost the high frequency to try and balance the sound. Thankfully the previous owner installed an aftermarket radio that gave me that option.
Nick 1972 Chevrolet C10 Stepside |
Could always do the kicks and a 8-10 shallow sub under the seat..
The Older Generation
There is also a new style speaker that replaces the original speaker. I think it is two speakers in one unit but they are kind of small. Here is a thread that might help.... http://67-72chevytrucks.com/vboard/s...d.php?t=524354 LockDoc
#15 |
![]() Join Date: Jun 2014
So I'm agonizing over the same speaker issues... Not going to remove my gas tank in the cab.
So with most (all) of the kick panel speakers, it's my understanding that there are issues with the emergency brake pedal clearance on the 71-72. IRT the speakers that Lock Doc refers to, do they have the proper mount/brackets to mount under dash in the stock location? TIA, Randy |
#16 | |
I think there are a couple of different styles and some of them do and some of them don't.... I have never used any of them. LockDoc
#17 |
I went to car toys and told them what I was doing and they came up with these speakers. I made a bracket/plate to mount them in under dash. I was shocked how good they sound. Part # 46211cfp
#18 | |
The e brake pedal does need a tweak , just heat it and bend it 1/2" give or take to the right.. The kicks that are like this allow for deeper basket speakers instead of shallow mount type.. if you go with the shallow 6.5" speaker and that type kicks. plan on no lower end and might want a single sub.. Of course this is an opinion, that depends on what you need for good sound.. |
#19 | |
Good for filler of sound.. It be nice if there was a stock sized dual voice coil speaker with twin tweeters. Edit looking at the LMC catalog they do. it's part # 38-8564 $69.00 The larger cone will give a much fuller range sound than any dual tiny speakers can.. without a ported box/cabinet.. open air type like the dash it just not happen. |
#20 |
Since the PO already hacked 6x9 holes in my doors, I might as well use them. I'm going with 6x9s in the doors, and dual 3.5s in the center dash. I've also got the tank behind the seat, so if I eventually add on a sub, I'll get a low-profile one under the seat.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205 66 Plymouth Barracuda 225 Slant6 |
