Old 01-26-2017, 09:17 PM   #1
jim-bob
Do These Two Wheel Dimensions ....
...put the tire in same position in fender well? All the measurements are the same except
one wheel has neg12mm off-set with 4" back space..the other has 0 off-set with 4.50 back space..If not, which wheel will put more tire toward the curb?
jim-bob is offline   Reply With Quote
Old 01-26-2017, 09:21 PM   #2
Kennuck
Kennuck's Avatar
Re: Do These Two Wheel Dimensions ....
depends on the wheel width
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 01-26-2017, 09:31 PM   #3
jim-bob
why? i said both wheels are the same except the o/s and b/s
Old 01-26-2017, 09:25 PM   #4
jim-bob
wheel drawing with -12mm off-set with 4" back space..If you move the mounting plate to 0 off-set won't that give you 4.50" back space?
Old 01-26-2017, 10:09 PM   #5
geezer#99
geezer#99's Avatar
The one with less backspace.
Old 01-26-2017, 10:13 PM   #6
Kennuck
Kennuck's Avatar
I misunderstood your question. The 4.0 backspace will put more tire to the curb.
1970 Short Wide
Vintage Air
Old 01-27-2017, 12:38 PM   #7
raggedjim
raggedjim's Avatar
Actually the negative offset on the smaller backspace will put the outside edge pretty close to the other. I think they will be so close you won't notice a difference.
If both had zero offset then the 4 back space would move the outer lip out, but negative offset of 12mm (a bit smaller than .5) will pull the outer lip back in.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is online now   Reply With Quote
