Old 01-29-2017, 12:42 PM   #1
wolfsden
wolfsden's Avatar
Window fix, need help please.
My 63 C-10 drivers side window when cracked fully up needs to close about another 3/8 inch. The glass is original glass and so is door and all components.
I included pics but its hard to see the top of window that needs to go up another 3/8 inch. is there some sort of adjust that needs to be done? Thanks for the help!
wolfsden is offline   Reply With Quote
Old 01-29-2017, 01:37 PM   #2
CRUZN66
CRUZN66's Avatar
Re: Window fix, need help please.
I found that on mine the lower channel was hitting the felt wipers so I took a heavy plastic clip tool that has the angled end and slightly bent the edge where the felt attaches just enough to clear the channel only where it was touching.
CRUZN66 is offline   Reply With Quote
Old 01-30-2017, 08:49 PM   #3
62 Barnfind
62 Barnfind's Avatar
I had the same problem. Just do what CRUZN66 says, it should fix it.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 01-29-2017, 02:13 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Post #6 and 17 here:
http://www.67-72chevytrucks.com/vboa...d.php?t=686833
Old 01-30-2017, 05:31 PM   #5
forestb
forestb's Avatar
I am having a similar problem only my window is going up all the way. The problem is that the channel is going in between the felt wipers and when it does it pushes on the door and causes the mettle on the outer door skin right below the window to push out a little. Normally I would not be to concerned about this but right after I had the truck painted the paint started to crack in that spot. I had that cracking fixed by the painter but am worried that it will happen again.
Is the channel supposed to go in between the felt wipers?
forestb is offline   Reply With Quote
Old 01-30-2017, 07:15 PM   #6
CRUZN66
CRUZN66's Avatar
Yes, that's why I just bent the lip in so the channel wouldn't catch on the felt wipers.
