Old 01-30-2017, 12:09 PM   #1
Jmh68C10
Jmh68C10's Avatar
1984 GMC C60 What went wrong while sitting?
I have a 1984 C60 with a 366 gas engine. Truck ran great when parked a year ago but now is getting no spark. Ideas?
68 c10- Under construction
Jmh68C10 is offline   Reply With Quote
Old 01-30-2017, 02:12 PM   #2
77 C-20 Scottsdale
Re: 1984 GMC C60 What went wrong while sitting?
Start by checking the wiring. Make sure rats or rabbits have not chewed the wires.
77 C-20 Scottsdale is offline   Reply With Quote
Old 01-30-2017, 07:52 PM   #3
demian5
demian5's Avatar
Make sure the wire from the starter to the coil wasn't eaten.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-30-2017, 08:04 PM   #4
geezer#99
geezer#99's Avatar
It doesn't have one.
It's an hei.
Old 01-30-2017, 02:22 PM   #5
maxx442
maxx442's Avatar
Distributor cap/rotor contacts may be corroded or oxidized. I'd also check your coil. Could be as simple as a loose ground.
maxx442 is offline   Reply With Quote
Old 01-30-2017, 08:05 PM   #6
johnthegreat508
Decomposed coil. Most likely corrosion of distro of connectors in the ignition wiring.
1973 Chevrolet C10 Stepside 454
johnthegreat508 is offline   Reply With Quote
Old 01-31-2017, 08:19 AM   #7
cadillac_al
If you have 12 volts at the distributor then it is the module. They can die anytime anywhere, especially after 30 years.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 01-31-2017, 08:49 AM   #8
Corrosion. I'd pull the coil out of the cap and check there, as well as inside the distributor. First try cleaning all that up with Lectramotive. Could be carbon tracks from bad cap.
Old 01-31-2017, 11:58 PM   #9
andyh1956
HEI's are notorious for the rotor buttons going bad.
andyh1956 is offline   Reply With Quote
Old 02-05-2017, 12:12 PM   #10
Jmh68C10
Jmh68C10's Avatar
Anyone have a wiring diagram of the wiring coming out of the HEI distributer? This looks a little suspicious.
Old 02-05-2017, 01:20 PM   #11
nonstop
The battery one next to it is still connected, right? That looks like it may have gone to a tach (tach terminal is next to the battery). Is there any chance it was touching ground? May be your problem right there. Try disconnecting it. Truck should run without it.
After looking again, hard to tell from the picture, but if that runs to the battery terminal of the cap, then that is your problem. It needs to be reconnected to the wire from the ignition. What is that heavy gauge pink wire connected to laying across the manifold? That looks like it should be the batter wire for the HEI.
nonstop is offline   Reply With Quote
