01-31-2017, 11:39 PM | #1 |
Front Hub Question
Greetings from Mississippi. I need some info on front hubs. I have an old '91 1 ton SRW double cab that may be pressed into service w/ a work body on it. I have a Dana 70 Dually rear axle for it. But I need to know if the dually front hubs will slide onto the single wheel spindles that are on the truck now, or if I have to hunt down spindles also. If they will work will the caliper brackets work also?
Thanks |
02-02-2017, 10:58 AM | #2 |
Re: Front Hub Question
They will. I converted my SRW to a DRW using only the DRW hubs. Even the calipers and mounting brackets worked just fine. Was also able to reuse my Warn hubs from the SRW set-up.
BTW the SRW front hubs demand a premium in case you think about selling them. |
02-02-2017, 11:09 AM | #3 |
Thanks for the help!
