Old 02-01-2017, 01:20 PM   #1
mrods72
mrods72's Avatar
Honey Dripper 1976 C10 build
I have been following this page for years and have enjoyed following member builds and decided it was time to post one of my current builds.
First off I purchased a 1978 Chevy SWB C10 from a local dealer in town when I was in high school (around 1999), it was a factory big block black with red interior and was still wearing its original paint. I drove it for a while and decided I wanted something different and sold it, I shouldn't have! That was a long time ago and over the years I told myself I would buy another one day. I was headed into town one day and saw this truck at a friends business for sale, I called him and we made a deal on it in July of 2015. It is a 1976 Chevrolet C10 SWB and he purchased it from a fellow member on this forum. First thing I did when I purchased it was order wheels, tires, brakes and all new suspension. It has been a work in progress since. November 11, 2016 I pulled the motor and trans for a severe under hood makeover and LS swap and I m getting close to finishing it.
mrods72 is offline   Reply With Quote
Old 02-01-2017, 01:26 PM   #2
mrods72
mrods72's Avatar
Re: Honey Dripper 1976 C10 build
Polished the paint, new carpet, headliner, dash pad, instrument cluster lens, and front and rear sway bars.
Old 02-01-2017, 01:29 PM   #3
mrods72
mrods72's Avatar
LS swap time
Old 02-01-2017, 01:31 PM   #4
mrods72
mrods72's Avatar
and progress
Old 02-01-2017, 01:33 PM   #5
mrods72
mrods72's Avatar
I forgot to mention its getting a little boost
Old 02-01-2017, 01:36 PM   #6
mrods72
mrods72's Avatar
Also installing a set of Slosh Tubz inner fender filler panels to clean up the engine bay.
Old 02-01-2017, 02:21 PM   #7
tinydb84
tinydb84's Avatar
Nice truck!!
David
Instagram: myfabguy
Old 02-01-2017, 02:59 PM   #8
mrods72
mrods72's Avatar
Originally Posted by tinydb84 View Post
Nice truck!!
Thank you!
Old 02-01-2017, 02:29 PM   #9
Low Elco
Oh, my. This oughta be exciting! Nice truck! Are you doing LST? C10s in the Park?
Low Elco is offline   Reply With Quote
Old 02-01-2017, 03:01 PM   #10
mrods72
mrods72's Avatar
Thank You! I don't think I will be bringing anything to LST, I went last year with a friend and it took us two hours to get in the gate. I will be at C10s in the park again this year, that is a great show!
Old 02-05-2017, 01:11 PM   #11
f.monroe
f.monroe's Avatar
Its coming along nicely .Glad to see it getting some attention .
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 02-05-2017, 11:14 PM   #12
Sik66
Looks good!....super sleeper!.....how'd you find the fit on that TRICK turbo manifold?...what engine mounts you running?....plenty clearance?
Sik66 is offline   Reply With Quote
Old 02-06-2017, 02:32 PM   #13
mrods72
mrods72's Avatar
Thank you! The manifold fits great with a little work. I had to massage the top of the engine stand on the right side a little, about a 1" of it. The engine stand has two raised bumps in it and the one closest to the firewall needed to be flattened out, I heated it with the torch and hammered it down just until it was as flat as the engine stand. I am running Dirty Dingo 73-87 motor mounts and I added some 3/8" plate in between the engine and the dirty dingo mount to allow added clearance for the manifold from the frame rail. Also the dirty dingo mounts are slotted and the motor is pushed over to the left side as far as the slots would allow.
Old 02-06-2017, 02:09 PM   #14
mrods72
mrods72's Avatar
Thank You! Are you planning to attend the car show in Bellville on March 11th? If so I plan to have it there.
Old 02-07-2017, 10:40 AM   #15
SCOTI
SCOTI's Avatar
Just park over in the spectator group. That's what I do (for the same reason).... It still takes an hour just to reach the spectators lot though but saves you big-time on the exiting delays
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-07-2017, 11:26 AM   #16
mrods72
mrods72's Avatar
Thanks for the info.
Old 02-06-2017, 02:41 PM   #17
mrods72
mrods72's Avatar
Made some headway this weekend, I am really close to starting it. I need to finish the charge pipe fab, fuel lines, vacuum lines, install my boost and air fuel gauge and fill it up with transmission fluid. I'm getting anxious!
Old 02-06-2017, 09:50 PM   #18
Tbags81C10
Do you happen to remember the specs on your turbo? and what trans are you running??
looking to 4.8LS swap my c10 after added bags and a dually rear end, definitely going to be following your build closely.
Tbags81C10 is offline   Reply With Quote
Old 02-07-2017, 08:59 AM   #19
mrods72
mrods72's Avatar
The turbo has a 76mm compressor wheel and .96 ar exhaust housing
Transmission is a built 4L80E
Old 02-12-2017, 10:47 PM   #20
77BBGMC
77BBGMC's Avatar
Cool pickup!
77BBGMC is offline   Reply With Quote
Old 02-14-2017, 12:03 PM   #21
mrods72
mrods72's Avatar
It's ALIVE!!! I worked my butt off Friday and Saturday getting the charge piping, vacuum lines and fuel system finished up. My buddy came by at 3:00pm Saturday and flashed the ECM and it started right up! I'm super excited and ready to take it for a spin!
Old 02-14-2017, 01:40 PM   #22
daddyjeep
daddyjeep's Avatar
Congrats...waiting patiently for a video.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 02-14-2017, 02:26 PM   #23
mrods72
mrods72's Avatar
Thank you! Working on posting a video now.
Old 02-14-2017, 02:23 PM   #24
Low Elco
Awesome! Looks great!
Old 02-14-2017, 02:47 PM   #25
mrods72
mrods72's Avatar
Thank You!
