02-03-2017, 09:52 PM | #1 |
Instrument Panel Help Needed/Newbie
Hello all. Been using this site since purchasing a 1971 shortbed at the end of last year. It has been very helpful and great resource. I have been utilizing the search feature but can't find a solution to this type issue.
My problem is this: Changed the instrument panel (with gauges) circuit board when I installed the reproduction tach conversion kit. Good news is that the tach works great along with the dash lights. Bad news is my turn signals on the instrument panel have gone haywire which wasn't a problem before. They seem to blink the hi beam lights(this didn't work before) and not where they should irregardless of the position of the turn signal switch. The turn signals on the body of the truck work fine so it has to be something instrument panel related. I am at a loss on where/what to fix this issue. The tabs on the connector appear to be OK. The bulbs were fine before I changed them over to the new board. Any help or suggestions would be appreciated. |
02-03-2017, 09:59 PM | #2 |
Re: Instrument Panel Help Needed/Newbie
I think there's a ground lead that clips to the metal dash. Make sure its clipped attached at both ends. The headlight switch also likes to be grounded so it should be attached. There's a color wiring diagram in a sticky somewhere in the reference area.
02-04-2017, 02:58 PM | #3 |
Thanks. Added an additional ground to the circuit board, check the dashbulbs to make sure they were making good contact and everyone seems happy now. On to the next electrical gremlin.
02-04-2017, 03:22 PM | #4 |
Did your truck originally have a 5 gauge instrument panel? Or a 3 gauge? Wiring harness is different for each, tach works because it is completely separate wiring
02-04-2017, 04:53 PM | #5 |
gotta love this forum!
02-04-2017, 06:08 PM | #6 |
It was an originally a 5 gauge cluster. It knew I was having so much fun that it just wanted me to take it out one more time and check everything again. May have been just adding an additional ground for the cluster, the new circuit board with the kit being weird or perhaps one of the dash bulbs was inserted incorrectly. Don't know and don't really care I am just glad everything works again.
Tags |
turn signal issues |
