02-05-2017, 08:44 PM | #1 |
What are your thoughts rcsb. 2000
I own 2 disassembled trucks 91 rclb. 4.3 5spd.130k Rust repaired box painted. Spindles hangers shackles installed. Need assembly and brake lines fixed. (Pinched behind gas tank tightening spring hanger bolts). 68 sbss. 2000 4.8 4l60. Totally disasembled.
Looking for daily driver. No longer want to drive 04 impala. I found at dealer 2000 short fleet 5.3 104k miles CLEAN lowered roll pan fiberglass cover. Ugly aftermarket wheels. $6k. Yes/no. Just assemble 91 and drive impala |
02-05-2017, 09:43 PM | #2 |
Re: What are your thoughts rcsb. 2000
02-06-2017, 12:09 AM | #3 |
the question is should i accure the 2000? add to the collection or bite the bullet get off my a$$ and make the 91 drivable,
BOTH then get after the 68 |
02-06-2017, 01:20 AM | #4 |
That's a good looking 2000! In all honesty it sounds like the 67 would go along way with your 91. Plus you already have a driver. So to answer your question, I would put that money towards your 91 and 68. I've done this before; looking back I could've done alot of nice things to my other rides at the time..
1979 Sierra Classic Heavy-half 1996 Silverado x-cab "the daily" |
02-07-2017, 01:12 AM | #5 |
you are probably correct. 91 is mostly labor away from driving. plan for stepside is red oxide SPI epoxy on everything but box put 4.8 in make run drive... i may be overmy head. if the right ## came along i would sell it.
02-09-2017, 07:47 PM | #6 |
6k for a 2000 SB with a 5.3 is a bit steep considering it's been modded so I'd try to get them down to 5K and that's only if it runs & shifts great with no CEL's and passes an inspection and smog test.
Keep that 68 and you'll have 2 mean looking Short Boxes. Sell the 91 for some build $$$ to spend on the 68. |
04-11-2017, 10:35 PM | #7 |
they came down wife said "buy the damn truck" turns out it has 5.3 3.73 limited slip. magnaflow duals cats still in tact. drives runs nice.
04-13-2017, 07:07 AM | #8 |
wife said tune the truck.... i had Czipar Performance tune it yesterday with hp tuners. big improvement however he told me the fuel pump is weak. said replace pump and bring it back so we can perfect the tune. on the 2 1/2 hr drive there i got 19 mpg. before tune. after tune may be worse it scoots for a heavy truck.
