Oil Pressure indication problems
This weekend my 05 GMC with 5.3 oil pressure suddenly pegged out at 80 psi. After a little research on the net I found that its a common problem on the 5.3 trucks. Nearly always replacing the pressure sensor seems to cure the problem. I picked up a new BWD S4202 sensor and replaced it this evening. Now when ever the ignition is on I have oil pressure bouncing between 15-20 PSI engine off or running doesn't matter. Just to double check I hooked the old sensor back up and it immediately pegged out at 80 PSI again. What are the odds I got a bad sensor? That sucker wasn't comfortable to change. lol. I guess tomorrow I get out the multi meter and see if I can figure out whats going on.
72 SWB parts and pieces Oklahoma |
#2 | |
Re: Oil Pressure indication problems
Turned out that I got a bad sensor. Replaced it again and everything back to normal.
Posted via Mobile Device |
