Old 02-17-2017, 09:36 AM   #1
69_hafton
Sleep-Deprived
69_hafton's Avatar
Tilt Column Shifts Out of Park Without Using Column Shift Lever
I noticed months ago - while I was working in the engine bay - that this tilt column will shift out of park without pulling the shift lever on the column. Pretty scary, I thought and I will have to be wary of this while working on/under the truck.
Where to I need to look for the problem? I've got the column torn down to replace the turn signal switch and am going to just rebuild it while I doing it. New bearings are in order and I was surprised to have to remove a mud-dobber's nest out of the hub.
1971 K/10 Long Fleetside
350/350 - 6" Lift
1969 C/10 SWB 292 - Sold It
69_hafton is offline   Reply With Quote
Old 02-17-2017, 10:36 AM   #2
60case
Re: Tilt Column Shifts Out of Park Without Using Column Shift Lever
The end of the shift lever get worn out
60case is offline   Reply With Quote
Old 02-17-2017, 11:26 AM   #3
69_hafton
Sleep-Deprived
69_hafton's Avatar
Thanks, I'm guessing it is as simple as that! The pointed end on my shift lever isn't square, but appears to be worn at an angle.
350/350 - 6" Lift
Old 02-17-2017, 01:12 PM   #4
bs46488
I just rebuilt my steering column and while I had everything apart I gave the shifter selector a couple tack welds and spent 10 mins filing it down. It certainly had some wear on it.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914
1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161
bs46488 is offline   Reply With Quote
