![]() Join Date: Dec 2000
Stock height (or 1" taller) ride height coil springs
I want to swap my old, stock 6-cylinder springs for stock height V-8 coils all around.
Little to no towing will be done....a little over stock height is fine. Any ideas? Thanks!
1970 Sub C-10 - 350/TH-350/3.73 12-bolt Came home from the hospital in it & mine ever since. 1966 Catalina Ventura 2-door fastback 389/TH400 |
![]() Join Date: Jan 2015
Re: Stock height (or 1" taller) ride height coil springs
Just get the Moog 3/4 ton progressive springs and put them in. You will gain a little over stock but they will ride a little stiffer as well.
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
I would think big block springs for the front would sit higher than a SB spring.
I have a BB with SB springs and it sat about an inch lower after I did the swap. I have since cut a coil off so I have no point to reference. I would think the same would hold true going the other way. IE SB motor with BB spring should raise the front higher.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
