5 bolt disc hubs to 6 bolt disc hub swap
I'm working on a rwd 1968 C/10 Panel Truck that has had the drum brake front suspension swapped out with a 1974 C/10 disc brake power steering front suspension. I would like to swap the 1974 5 bolt hubs back to the 1968 6 bolt hubs and am wondering if anyone has done this and what parts would fit?
Thank you!
Nothin' but time! |
Re: 5 bolt disc hubs to 6 bolt disc hub swap
You can use aftermarket 6-lug conversion hub/rotors instead of the factory disc brake 5-lug hub/rotors. You will need 6-lug disc brake spec wheels though. Factory 68 6-lug drum brake wheels won't clear the calipers.
Classic Performance Parts Early Classic Enterprises Performance On Line Summit Racing McGaughy's
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
