02-22-2017, 05:12 PM | #1 |
Help with wheel size
I am on the verge of ordering some 15"x8" Polished Torque Thrust II wheels for my 72. I want to make sure that they will fit. I took a front wheel off and measured the following using a straight edge across the wheel rim and a tape measure. Here is what I got as close as I could figure:
Backspace (flat part of hub to rim on back of wheel) = 3 1/2" Offset (center of wheel hole thickness to rim on front of wheel) = 3 7/8" The wheels that I am looking at are 3.79" back space and -18mm offset. (See picture) Do you see an issue with the fitment of these Torque Thrust wheels? My primary concern is the front. Thanks in advance for any advice. |
02-22-2017, 05:18 PM | #2 |
Re: Help with wheel size
02-22-2017, 06:09 PM | #3 |
Entered the following:
Tire size = 265/50 R15. Rim size = 8" What would I enter in the offset box? Thanks for the help |
02-22-2017, 06:17 PM | #4 |
try to find an offset that equals whatever backspacing you are looking at on the diagram...example on an 8 inch wheel, 0 offset usually comes up to 4.5 inch backspacing...and the offset in your pic up there is -18
02-22-2017, 06:26 PM | #5 |
and as I sit here and think about it....I have a set of TTO 15x8.5 with that exact backspacing on my truck now and I bought a set of 18x8 with the same backspace....both fit fine
02-22-2017, 06:08 PM | #6 |
Sub
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-22-2017, 07:27 PM | #7 |
Are those wheels in pic the AR Outlaw II models perhaps?
02-22-2017, 07:33 PM | #8 |
I don't want to hijack your question, but there are SO many more choices for tires in 17" it seems crazy not to move up. I know on the front of my 69, the zero offset 17x8 would rub on the tie rod if it was a zero offset 15x8 (4.5" backspace).
235 55 17 on a 17x8 zero offset is a great setup that looks awesome IMO and fills the wheel well much better than any of the 15" choices.
02-22-2017, 11:41 PM | #9 |
Thanks for the help. Have an appointment on Friday with a guy who will get me straightened out.
02-23-2017, 12:12 AM | #10 | |
BlahBlahBlah
http://67-72chevytrucks.com/vboard/s...d.php?t=703601
