02-27-2017, 06:43 PM | #1 |
Slammed 63 gmc c20
Hello all. I am new to this forum but from what I can tell you guys rock. Enough of the add kissing and into my point. I have just picked up a sweet 63 gmc c20, v6/305. 8 lug. Here is my dream for this old girl. Slammed and bagged but want it done the right way. I'm aware I need to c notch and that's about it... I've lowered plenty of s10 in my day but C20 is a first. I want to lower it as much as possible now until I get all the parts to slam it. 1st question. How can I lower this girl as much as possible on a budget without tearing shot up too bad. *grocery getter not a long road driver* 2nd question. What do I need to slam it besides the c notch, air ride kit. The front I'm still confused besides spindles but will that be an even lower IE level? Any input will help and greatly appreciated. I'm also looking for a stock radio that fits that truck. Converting it to mp3 to be more rad!!! Thanks again guys!
02-27-2017, 08:02 PM | #2 |
Re: Slammed 63 gmc c20
Is it leaf or coil in rear?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
02-27-2017, 08:06 PM | #3 |
Leaf springs. Also another question. There is stock wheels on it now and when I slam it I want detroit steels on there. 20's maybe. I'm thinking I would have to tub the wells? Correct?
02-27-2017, 11:15 PM | #4 |
If your talking budget build then you need to forget about those wheels and tires. Get it safe, get it running and enjoy it like it is, save some $ and make a plan to do some smaller jobs while you drive and enjoy. Other wise your probably going to loose intrest and sell at a loss.
02-28-2017, 01:26 AM | #5 |
60-66 Nut
Welcome to the forum
What is working against you from the start is that you are starting with a C20 and not a C10. I do not know of a lower balljoint that will press into those C20 lower control arms and accept a C10 dropped spindle. But then again, I have never attempted what you are doing either. There may be something out there that I am not aware of.
02-28-2017, 01:18 PM | #6 | |
67-72 parts collector,…
They aren't cheap. Probably because they don't sell as many. Back to the OP's question. Cheap and good lowering jobs don't go together. You will need a flip kit, drop shocks, drop spindles, drop coils or cut coils up front, and a c-notch at a minimum,... for your average 5/7 static drop. To get your truck lower will require much more work and much more money,...
02-28-2017, 12:56 PM | #7 | |
02-28-2017, 01:21 PM | #8 |
This is a 67-72 style c20 drop,... using quality components.
http://67-72chevytrucks.com/vboard/s...d.php?t=691739 The front will be the same,... and the rear will be different. I know it's bagged,... but a lot of the same stuff applies. It's a good thread.
