Old 03-02-2017, 09:32 AM   #1
Rich84
Rich84's Avatar
Lq4 Swap has Finally Begun...
So after lurking around here for a couple years I finally took the plunge.
Two Sundays into my swap. This might take a while, since I can only work on it on the weekends.
What I have: 1984 Sierra Stepside
Lq4 from a 2005 Isuzu NPR
Dirty Dingo Sliders
1987 fuel tank and sender
Corvette regulator
4l80E
Crown Vic Aluminum drive shaft
30 spline 10bolt Posi 373's
dual fans and radiator from 2006 Escalade
with relays and wiring
Harness from Fuel Injection Connection
Trailblazer ss Manifolds
Was hesitant to pull the trigger on the swap because the truck ran so well with the TPI that was in it.
I'll get some pictures up as soon as I can.
Rich84 is offline   Reply With Quote
Old 03-02-2017, 12:21 PM   #2
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Re: Lq4 Swap has Finally Begun...
Cool! The swap will move faster than you think, keep us posted!
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 03-02-2017, 03:28 PM   #3
nastety92
Do you already know that this driveshaft will work for you application?
nastety92 is offline   Reply With Quote
Old 03-02-2017, 03:36 PM   #4
Rich84
Rich84's Avatar
It was the driveshaft that I was using with my 700r4 and TPI setup. The 4l80e is a couple inches longer, but I think based on my ruff measurements that I slid the engine forward enough to still use it. The lower A/C mount should work also as it does clear the mount.
Old 03-02-2017, 04:21 PM   #5
mongocanfly
mongocanfly's Avatar
Yep..your gonna have a big grin when you get done
Old 03-02-2017, 04:29 PM   #6
Rich84
Rich84's Avatar
Looking to get the radiator and fans in this weekend. Then it's on to dressing the engine with the accessories and exhaust manifolds. Picked up the conversion u-joint this morning for the slip yoke to get the driveshaft in also.
It's supposed to be only 25* this Saturday and my garage is really tight. I don't want to disrupt the momentum to get this thing running.
Old 03-02-2017, 04:40 PM   #7
mongocanfly
I just kept my stock radiator when I did my lq9 swap and added dual fans to it..no problems..the caddy radiator may take some work to make fit
Old 03-02-2017, 04:44 PM   #8
Rich84
Rich84's Avatar
My stock radiator was weeping coolant...So I need a new one anyway.
Old 03-02-2017, 04:46 PM   #9
Rich84
Rich84's Avatar
Old 03-04-2017, 03:29 PM   #10
LeesTruk
Rich, if you got questions or need help, I'm just up I84 in Manchester
Lee
LeesTruk is offline   Reply With Quote
Old 03-06-2017, 04:48 PM   #11
Rich84
Rich84's Avatar
Thanks Lee..So far so good. But it's early.
Got the drive shaft in and radiator mounted this week as planned. It's going to be a couple weekends until I get back into it. So many little things to do it's starting to get a little overwhelming.
Old 03-10-2017, 02:01 PM   #12
Rich84
Rich84's Avatar
Slow process..Radiator and fans are in.
Old 03-27-2017, 09:37 AM   #13
Rich84
Rich84's Avatar
So I pulled the fuel rails off the intake..The gas was nasty brown and the injectors look nasty.
Any pointers on how to clean the injectors?
Old 03-27-2017, 12:37 PM   #14
dec010974
dec010974's Avatar
Hello. submerge the fuel injectors in Seafoam a day or two. Good luck with your LSx swap
dec010974 is offline   Reply With Quote
Old 03-27-2017, 04:25 PM   #15
Rich84
Rich84's Avatar
Can you submerge the injector? Or should you keep the electrical part out?
Old 03-27-2017, 05:38 PM   #16
MalibuSSwagon
submerge the whole thing. It'll ruin the o-rings tho and you'll have to replace them. I used B12 chemtool injector cleaner, the type you dump in your tank.
If the injectors are real bad a trip to an injector shop is not a bad idea.
MalibuSSwagon is offline   Reply With Quote
Old 04-28-2017, 12:13 PM   #17
Rich84
Rich84's Avatar
I was traveling most of April, but I'm diving back in this weekend.. Fuel system is ready to go. Going to be working on the wiring this weekend. I hope to be able to pull it thru the existing hole in the firewall. I will be mounting the computer under the dash behind the glove box. I have my nephew at the muffler shop making me a couple of pipes that I hope I can patch the exhaust well enough to start the engine.
Old 05-02-2017, 11:31 AM   #18
Jstock85
On your fuel system what filter did you use and how did soaking the injectors turn out?
Jstock85 is offline   Reply With Quote
Old 04-28-2017, 12:31 PM   #19
solidaxel
solidaxel's Avatar
Don't forget the front O2 sensors!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-28-2017, 12:39 PM   #20
Rich84
Rich84's Avatar
I have two short stubs with the sensors in them attached to the manifold. Hoping to splice a pipe from there to my existing exhaust. Passenger side shouldn't be too bad. The driverside is a little more crowded with the shift linkage and the fuel lines crossing over to the frame.
Old 05-01-2017, 11:08 AM   #21
Rich84
Rich84's Avatar
So I got the wiring pulled thru the firewall, computer is mounted, Gas pedal is mounted, fans are wired.
I do have a question about he brown wire that I believe goes to the voltage gauge.
Where does it go? Or is it not needed?
Old 05-01-2017, 11:21 AM   #22
cooperhw
cooperhw's Avatar
LS1 Tech is the place to have any and all questions relating to an LS motor answered.
"Every" question you could ever have has been asked and answered for the last 15 years.
On this truck forum a few guys have ls motors. On LS1 Tech "everybody" has ls motors. They have a pinout guide that will show you "EVERY WIRE" that comes out of your computer. Where it goes and if it is needed or not.
hope this helps.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 05-01-2017, 11:26 AM   #23
cooperhw
cooperhw's Avatar
Try this shortcut.
http://lt1swap.com/2000harness.htm
Later,
Wayne
Old 05-01-2017, 12:26 PM   #24
MalibuSSwagon
Are you talking about the brown wire from the LS truck harness? That should go to the PCM. Or about the original wire that regulated the alternator? I just removed the brown wire from the C10's original loom.
Old 05-01-2017, 04:24 PM   #25
Rich84
Rich84's Avatar
Yes..I was talking about the wire from the truck harness.
Thanks, I'll pull it out.
