10-17-2003, 03:53 PM | #1 |
differential question
Heres a good one. I went to check the gear ratio on my dump and I jacked up the rear end and spun the tires around twice but my driveshaft only moved about an inch. I do know the gear ratio is not .125:1 so I am wondering what the heck is wrong with this picture. I have been driving this truck all over since I got it inspected a few days ago with no problems so I do not think there is anything majorly wrong with the diff. Anyone have any ideas? I will probably pull the cover soon just to take a look but I do not want to do it if I don't have to. It is the eaton HO 72 I think unless they made another one for the one tons. It looks like it would have a nine or ten inch ring gear in it from the size of the housing. Might as well post a pic.
10-17-2003, 04:07 PM | #2 |
I believe with an open diff, both tires are going to have to be rotated at the same time to get a correct reading.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
10-17-2003, 04:18 PM | #3 |
Thanks Yukon,
That did the trick, It's a 410. Do you know if you can still get posi units for the one tons? I seem to remembr reading somewhere that eaton does not make them for the larger axles anymore.
86 Silverado C10 back to 305 power! 67 C30 Dually Dump, with 350 transplant, Rockhauler 05 Duramax 3500 "If at first you don't succeed, try a bigger hammer" Member of the 1-Ton club! |
10-17-2003, 04:25 PM | #4 |
They do not make new ones anymore, but you can find them around if you know what you are looking for. I've picked up quite a few lockers over the years. Don't forget to look at the pre-67 trucks also. They used this rearend for a long time.
And don't let rusty teeth scare you if you do fine one. Swapping your good 4.10 gears with it is not a big deal on these. |
10-17-2003, 04:38 PM | #5 |
Thanks Dean,
are they eaton or the detroit lockers? I guess I have to pull the cover and see how many splines on the axle in order to start looking. GM was using this axle since the fourties right? I do not think I want one that is that old but I will start looking. Maybe I will post on the parts board.
10-20-2003, 01:43 AM | #6 |
I remember reading on this board in sometime in April/May that this axle ran from 60-72.
10-20-2003, 04:34 AM | #7 |
user # 2756
It's a detroit locker.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
10-20-2003, 07:15 PM | #8 |
Thanks for the replies.
10-20-2003, 10:00 PM | #9 |
The detroit lockers of this vintage look like this one of mine. 17 spline. There spring loaded so to keep them around you put a bolt and nut with big washers through the middle of it all.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
10-20-2003, 10:07 PM | #10 |
Heres a detroit locker disassembled but I dont think this one was exactly correct ... but they all pretty much look the same inside except for spline counts anyway in these older ones.
10-20-2003, 10:23 PM | #11 |
And when you first get a unit in a whole piece it looks like this.
And its gotta weigh over 75 pounds.
10-20-2003, 11:32 PM | #12 |
My other Love
i have seen a lot of 60-66 one tons in my area with the "no spin" plate on the glovebox door, so they can't be overly hard to find
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
