Old 03-13-2017, 03:43 PM   #1
Jaysonb
Jaysonb's Avatar
73 dash bezel
The wood grain on the dash bezel of the 73 I'm working on is all tore up. When I look for an aftermarket bezel, it seems that there is none for 73, or 74? Anyone know what will work for this 73?
Jaysonb is offline   Reply With Quote
Old 03-13-2017, 06:05 PM   #2
ray_mcavoy
Re: 73 dash bezel
I believe the 75 through 77 bezels will fit 73 & 74. And so will the 78 through 80 bezels as long as you use the matching cover panel that fits below the steering column.
But there are few differences. For example, the 75+ bezels have a slightly wider rectangular opening for the windshield wiper switch. And the 75+ bezels no longer have the slightly raised up section surrounding the headlight switch knob and instead have a larger round hole. The appearance/styling also changed a bit, especially with the 78+ bezels.
ray_mcavoy is offline   Reply With Quote
Old 03-13-2017, 08:05 PM   #3
Pontiac1976
Pontiac1976's Avatar
Re: 73 dash bezel
This should help
http://bowtieguy.proboards.com/threa...ce-bezels-fits
E-bay maybe the place to look, if you want to keep it factory
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-15-2017, 11:17 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 73 dash bezel
Originally Posted by Pontiac1976 View Post
Excellent post. Its unfortunate that some of the pics are missing.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
