Old 03-17-2017, 08:56 AM   #1
carryall
Seat Question
I have a seat out of a 1990 Chevy Truck. I want to mount it in my 1970 Chevy Truck. Can I mount my seat brackets from my original seat to the seat out of the 1990 Chevy truck? Thanks
1967 Chevy Truck
1969 Chevy Panel Truck work in progress
1971 GMC 1500 all orginal
1972 Chevy Suburban brought from orignal owner
1984 Dodge Rampage 45,000 original miles
1992 Dodge D150
1994 Buick Roadmaster (LT1 Engine)
2000 Chevy Stepside Z71
2008 Honda Element
carryall is offline   Reply With Quote
Old 03-17-2017, 10:34 PM   #2
ratty69
Re: Seat Question
It's definitely not plug-and-play, but it can be done. Here's some pics of my in-progress swap. It's been back-burnered since I've got way bigger fish to fry with this truck. It WILL be cleaner looking when done.
Note, I used a set of 72 tracks, but it should work with other years too.
Basically, for the front, you make adapter plates to pick up the original hole in the seat plus drill one.
For the rear, you need to heat and bend down the seat mounting point on the track at about 3/4" above the track. Then make adapters similar to the front.
Bolt your tracks into your cab.Set the seat on top, and measure/move until centered. Mark plates where tracks end up, then remove.
Front of tracks should have plenty of space to bolt to the plates. In the rear, you will probably have to weld the tracks to the plates because the original seat mount hole will end up right on the edge of the track ( at least mine did ).
Sorry for the long-winded post, but hope it helps.
ratty69 is offline   Reply With Quote
