Old 03-17-2017, 11:56 PM   #1
SunSoaked
SunSoaked's Avatar
NV4500 conversion questions: X-member/Seat
I'm going to swapping a nv4500 into my 85 K20 that currently has a turbo 350.
I got two questions that I'm hoping someone can answer:
1. Transmission X-member-are they different? How so?
2. Does the factory floor shifter clear the bench seat?
Thanks for any help.
Mike
SunSoaked is offline   Reply With Quote
Old 03-18-2017, 09:09 AM   #2
meatwagon83
meatwagon83's Avatar
Re: NV4500 conversion questions: X-member/Seat
I just did this swap in my truck, but mine is 2wd, yes the shifter clears, I have heard that you can use the same crossmember, I did, but again, mine is 2wd
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 03-18-2017, 09:12 AM   #3
meatwagon83
[/URL]
Plenty of room!
Old 03-18-2017, 10:54 AM   #4
mongocanfly
mongocanfly's Avatar
i swapped my sm465 for a nv4500..its 2 wheel drive as well..shifter clears fine and I reused my crossmember but had to move it back 1 1/2" ...which means shortening driveshafts.. measure case length of both trans to give you an idea..
Old 03-18-2017, 01:40 PM   #5
meatwagon83
I had to move my crossmember forward about 2 inches, and have my driveshaft lengthened, I went from a t400 to a nv4500 though
Old 03-18-2017, 10:21 PM   #6
SunSoaked
SunSoaked's Avatar
Thanks Meat & Mongo,
So the 4500 fit within the trans tunnel? You just had to move the shifter opening forward or back, correct?
Thanks, Mike
Old 03-18-2017, 10:48 PM   #7
mongocanfly
Yes ..I had to move my shifter hole back from where it was original and mine has the high tunnel and it had plenty of clearance
Old 03-19-2017, 08:27 AM   #8
meatwagon83
I had to put a high trans hump in mine since it was 2wd auto
