Old 03-22-2017, 09:44 AM   #1
joesscamaro
Vintage Air Guidance
All, I'm in the process of ordering some parts for my truck and wanted to get some opinions on the Vintage Air system I'm going to order. I'm going to be doing an LS1 conversion and when I was speaking to the sales person they asked if I was going to use the stock LS compressor and LS drive system. They also gave me the option to go aftermarket compressor and the necessary bracket. What are the advantages of going aftermarket compressor, if any? Why wouldn't I just use the stock equipment? Any advice is appreciated.
joesscamaro is offline   Reply With Quote
Old 03-22-2017, 10:07 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Vintage Air Guidance
FAQ section of this website - http://67-72chevytrucks.com/vboard/s...d.php?t=467956
Vintage air? Who has it in their truck - http://67-72chevytrucks.com/vboard/s...d.php?t=467956
OLD AIR vs VINTAGE AIR - http://67-72chevytrucks.com/vboard/s...d.php?t=337366
Vintage air vs Classic Auto Air- Anyone? - http://67-72chevytrucks.com/vboard/s...d.php?t=636980
Vintage Air vs. LMC - http://67-72chevytrucks.com/vboard/s...d.php?t=707546
Old 03-22-2017, 10:25 AM   #3
joesscamaro
Thanks for the links! I'm fairly familiar with the actual system, after doing quite a bit of reading. I am just wondering if there is any specific reason people go with the aftermarket compressor instead of using stock? I plan to use my stock compressor unless I am persuaded otherwise.
Old 03-22-2017, 10:35 AM   #4
racecougar
racecougar's Avatar
From what I see thus far (just set my engine in place), you'll have to give up a bit of engine set-back in order to fit the stock LS AC compressor. I can snap some photos this weekend if it will help.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 03-22-2017, 10:43 AM   #5
joesscamaro
Yeah, that would be great! I was wondering if it was mainly just a fitment issue. I haven't sent my payment yet, so I may end up adding the compressor and bracket to my order.
Old 03-22-2017, 11:11 AM   #6
TopFuel1966
TopFuel1966's Avatar
I've had no issues with using the factory compressor and mounting location on my 5.3. The fit is a little tight against the frame but the compressor is easily accessible from the bottom side.
TopFuel1966 is offline   Reply With Quote
Old 03-22-2017, 04:56 PM   #7
cooperhw
cooperhw's Avatar
The reason they ask about the stock (to the LS motor) compressor or aftermarket is because the stock compressor often times has a "variable output compressor" (probably not correct word) as opposed to the aftermarket unit will either be on or off with no in-between. I would recommend using the aftermarket unit. I tried the new compressor (came with the accessory drive kit from GM) on my last build and finally took it off and replaced it. aftermarket unit worked well.
Call Vintage air. The Tech guy is happy to talk to you and explain it better.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 03-22-2017, 09:08 PM   #8
racecougar
racecougar's Avatar
This is the best pic I have at the moment; I can get a better shot this weekend. Clearance to the frame doesn't look to be an issue, but the engine mount plates completely overlap the compressor mounting. That can be mitigated by moving the engine forward, but I don't want to go that route.
Old 03-23-2017, 02:18 PM   #9
drmatera
drmatera's Avatar
Originally Posted by racecougar View Post
wow, your engine is set way father back than mine. Maybe I have the mounts in wrong
1981 K10 (4.8 / 4L60E swap)
1982 C10 (5.3 / 4L80E swap)
1985 C20 Suburban (454 / 4L80E)
drmatera is offline   Reply With Quote
Old 03-22-2017, 05:58 PM   #10
joesscamaro
Thanks for the picture!
That's the problem and frustration for me right now...I'm currently overseas for work and don't have access to a phone. So, I've been talking with them on here and it's hard sometimes to get everything across. That's why I was asking for personal opinions. Thanks for the input though! I may just add the compressor and brackets to the list.
Old 03-22-2017, 09:24 PM   #11
joesscamaro
Oh yeah, it looks like you won't have much, if any, clearance for the compressor. Are the aftermarket compressors smaller in size?
Old 03-23-2017, 10:52 AM   #12
cooperhw
cooperhw's Avatar
I bought a mount bracket kit from Dirty Dingo and it moves the compressor way up high and out of the area where the frame is. Works like a charm.
Later,
Wayne
