![]() Join Date: Jul 2016
I remember prior Owner telling me he put silicon in leaks under dash - I found the three (3) factory holes he filled when restoring my '67 Chevy C20. See picture, this is one I found on passenger side. There is same on driver side and in middle of dash at windshield had covered by windshield seal.
* Can some one explain the WHY and won't any moisture just go into wiring and things under dash? R/ DJ |
![]() Join Date: Jul 2015
Re: Drain Holes on Dash Inside Windshield
It does (rain). I am fighting a cowl leak and bad seal? The cowl area I have patched twice now with buytl rubber and it's still leaking in.
Trust me, we get some rain here along the Gulf Coast
![]() I had annoying water leak onto dash and under dash and replacing wiring now due to corrosion --- trying to find and fix anything that may be leaking. Going to replace wiper motor seal and try to better seal cowl area --- thought I had. |
![]() Join Date: Feb 2016
Basically someone at GM made a decision based on what they thought was a good idea. It may have been to drain the soapy water off the dash after the glass was installed, or to let condensation that drips off the glass have some place to go. It's one of those things we will never know.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Thank you HO455.
So no reason I don't plug these drain holes? If I have water on the dash, I want to know about it and not just go into and under the dash and wiring. R/ DJ |
sub'd
![]() Join Date: Dec 2013
Don't plug or seal the dash weep/drain holes , they are there for excess condensation in a 50 year old truck , if you have water leaking into your cab it's coming from outside from a leaking cowl or bad windshield gasket , time for you to crawl in upside down with a flash light while someone helps by pouring water into your cowl vent so you can find the leak , those little dash vents have nothing to do with water leaking into your truck , time to pull your exterior cowl panel off and start looking for the leak , also clean all the leaves and debris out and check the lower vent drain scuppers to make sure they are not plugged and draining correctly
Posted via Mobile Device |
I agree with Grumpy. What you are worried about is water from outside, not a "possible" drip every once in a blue moon from condensation. The problem is elsewhere. I recommend going under the dash "w/o" a flashlight to look and having a friend "with" a flashlight shine it so the light will come through any breeches. If you don't catch light peeping through it isn't a direct path and it's time for the light under/water up top system
Thank you both (Grumpy Old Man & special-K)!
I am completely going thru cab now replacing anything rusted beyond repair with patch panels to include the drip rails over doors. Passenger side must have been left exposed because most damage there. Cowl looked OK, and will take another look at that, seal it good and replace windshield wiper seal too. Then check for leaks as you both explained - again. I came across those weep holes and knew there had to be a good reason. Thanks again for sharing the wealth of information experience brings. R/ DJ |
Agree that water in the cab is annoying, and that the cowl area of our old trucks was not well designed in terms of preventing rust. I've had my outer cowl panel off, and thoroughly cleaned that area. I am concerned about leaves and other debris in the kick panel vent areas of these trucks. I can reach in, and find old leaves. Is there supposed to be a water drain in the bottom of those vent areas?
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
#12 | |
That's a good question Rick. I have access and can add vent holes there now, but note that is not an area I have rust to fix on this '67 Long Bed C20.
DJ |
I done that but GREAT advice to LongBox. I thoroughly cleaned and painting with quality rust converter to keep problem at bay.
#15 |
I don't know if Grump is right - I assume he is - but my take on it is this:
GM didn't do anything that cost any money if it didn't have to be done. If it cost them 50 cents to drill those holes on a truck, that's half a million dollars some dude in jazzy suit didn't save them. That's a fat bonus in 1967 dollars! If only it worked that way... But suffice to say GM didn't do a lot of unnecessary steps, and if they did, they often economized them out of the process by the end of a model run. So, if you see it on all 5 years of our trucks, it's probably required. If you see it in the 67s but not the 72s, it's probably a good idea. If you see it in the 72s and not the 67s, it's something they had to add during production and is therefore probably a very good idea. Those are just my general guidelines. I assume these holes are there for a reason (condensation most likely). --- To Longbox: wear gloves!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#16 | |
#17 | |
Posted via Mobile Device Last edited by Grumpy old man; 03-27-2017 at 01:53 PM. |
#18 |
I glued window screen under the slots of my cowl cover. I had truck painted which painted window screen - you can hardly tell its there. Keeps a huge amount of leaves and pine straw out.
