66 C 10 Custom Question
Hello, I was once the owner of a 1966 black C10, LB Custom cab, with large back window. It had chrome grill and front bumper, and chrome down the sides.
Also equipped with 327 2bbl and 4 speed. I regret ever selling the truck, but at the time I was going on to bigger and better on a steady basis. My question to you fellers is, the truck had a cast iron oil pan, with a circular plate on the bottom of the pan with 8 to 12 bolts holding it on. Similar in appearance to the bottom of a VW bug engine with a strainer plate. The one on my 327 was much bigger probably 6" to 8" across, the truck also had a canister type oil filter. I described this to many people over the years and nobody was familiar with this, anyone know anything about this 327? I always thought it was the original engine, but had no history on it before I owned it. Thanks Greg |
60-66 Nut
Re: 66 C 10 Custom Question
That oil pan could possibly have been for a marine application? Or maybe an industrial application. I have never seen anything like that on a car or truck.
#3 | |
Greg |
It's Better With Nitro
As the others mentioned, other applications that required or had a need for mounting/support along the oil pan - marine, power generation, tractor, etc. - often use a cast iron oil pan with mount provisions.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
