10-19-2003, 04:13 AM | #1 |
LED King
LED bulbs for dash
Call me the LED king. I just installed LED bulbs in my dash including all the "warning" lights (Check engine, brake,choke,highbeams) I found a place that sells them for cheap. I like it so far. It is a little dimmer than before, but I am installing white face overlays only. I installed a blue one in my Heater/AC controls. It looks cool! I need to do some juggling around and order other ones since I ordered 2 of every type of bulb, leaving my with odd buls in odd places. Like a green one in my tach. I put green LEDs in place of my turn signal indicators and like it much better.
Problems: I cracked almost all the mounting tabs off the cluster. I knew it was going to happen.... My temp. gauge has stopped working. Probably just a loose connector??? My voltmeter now reads slightly more that it used to (1-1.5 volts). Why would this happen?? Weird.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
10-19-2003, 04:14 AM | #2 |
LED King
If you want the site for the LED bulbs, PM me. It is a tad bit confusing as they don't have the bulbs under the names you think they would. I have catolog #s that make it 200% easier.
10-19-2003, 09:51 AM | #3 | |
Re: LED bulbs for dash
Corny but what im trying to sat is some times you have to mess something up to end up with something better #2. You’re probably right #3. The close proximity of the old incandescent bulbs my have had an Electro magnetic effect on the gauge that L.E.D. don’t have. I know this ones a stretch but hey it’s possible. Any ways it sounds like you’re on the right track and when you get a chance send me a PM on were to find the bulbs. Thanks Dan
10-19-2003, 04:52 PM | #4 |
so if they are slightly dimmer, why would you keep them on there. i used blue covered bulbs once. they were dimmer. after about a month, i pulled them and put all new white bulbs
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
10-19-2003, 04:54 PM | #5 |
Professional Grade
I would guess that not having inefficient filimant bulbs probally saves some energy... I know that on ever bass hit my electrical guage falls :P
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
10-19-2003, 07:13 PM | #6 |
Stylin
i had to goto a 100 amp alternator to fix that problem and i have a optima yellow top battery also the whole stupid voltage gauge needle bouncing only happens when ive got the turn signals on lol
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
10-20-2003, 12:48 PM | #7 |
LED King
Jeff - I'm going to put the white face overlays on then it won't matter. I don't drive much at night anyways.
Today the temp gauge started to work, then next time I looked it was dead again. Loose wire! I'll need to look into that. The voltmeter thing still eludes me, but if the power is routed through the circuuit board and a light before it gets to it, it could cause the sudden increase in volts to the gauge.
10-20-2003, 06:20 PM | #8 |
Insert Witty Text Here
Can you use LEDs on a rheostat? What happens if you dim the dash lights with LEDs in there?
Slonaker |
10-20-2003, 08:50 PM | #9 |
Pm'd you on the lights........Thanks,
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
10-21-2003, 01:10 AM | #10 |
LED King
I'm going to try the LEDs with a pot. The LEDs don't change much when you turn the dimmer in the truck.
I got them from www.digikey.com you can also get them from mouser Electronics at www.mouser.com These part numbers refer to digikey. These are listed under "based LEDs" - "LED miniature wedge base" There are two types. "Milky" or "water clear" - you will want the milky. The water clear are -brighter- but focas it in one direction. The milky ones look much more like bulbs in light dispersion. All part numbers refer to milky diffused. White: milky diffused - 441-1008-ND - $1.60 Blue: 441-1006-ND - $1.50 Green: 441-1000-ND - $1.60 Yellow (orangish amber): 441-1002-ND - $.99 Red: 441-1004-ND - $.99 Use the red and yellow for the warning & indicator lights. Use the green for the turn signals. Use a blue for the brights indicator and possible the Heater/AC controls. Use white for the gauge lighting and possibly Heater/AC controls. If you live in CA, don't forget the extra check engine light when you order. It looks orange (like the 4X4, glow plugs,& choke), but the yellow LED matches exactly.
10-21-2003, 08:50 AM | #11 |
Thanks for the links......
10-21-2003, 12:18 PM | #12 |
I had some superwhite bulbs behind the four smaller gauges on the left side, looked pretty good, gave them a nice tint. Don't feel like spending $4.00 for 2 bulbs.
1987 Chevrolet Silverado 2005 Chevrolet Silverado |
10-22-2003, 11:31 PM | #13 |
LED King
ttt - kicking this up for anyone else interested...
