Old 04-05-2017, 02:46 PM   #1
AirSpeed
AirSpeed's Avatar
What's making my front brakes lock up and stay locked up?
Driving down a curvy mountain road the other day and applied the brakes to slow around a corner and my front brakes wouldn't release. I pulled over and tried going back and fourth hitting the brakes and they finally let go. This is on my 72 GMC K1500. I have power disc brakes on the front and just replaced the calipers a couple years ago. I looked for anything lodged in them but found nothing. This has since happened a couple more times. Any idea what would cause this?
AirSpeed is offline   Reply With Quote
Old 04-05-2017, 02:56 PM   #2
Southcity
Southcity's Avatar
Re: What's making my front brakes lock up and stay locked up?
I would start with a good visual check of all your brake components:
1. Is the fluid clean and at the correct level in the master cylinder?
2. Do you see any leaks/wet spots around the master cylinder, proportioning valve etc.
3. Follow all the lines from there down to the front calipers, any leaks?
4. What is the state of the rubber flex lines between caliper and hard lines? are they old and cracking or are they newer and replaced when you did front caliper replacement? are they binding up anywhere?
5. Break a bleeder screw loose on one of the front calipers, does fluid come out? maybe have a friend pump the brakes when you break a bleeder screw loose to see if you get fluid.
Eliminating some of the above should help you know where to concentrate the troubleshooting efforts. Hope this is helpful, let us know your progress as others will chime in to help out.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 04-05-2017, 03:11 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
I would start with the rubber hoses. They can collapse inside and hold pressure if they get bad...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 04-05-2017, 03:18 PM   #4
AirSpeed
AirSpeed's Avatar
The hoses don't look bad on the outside but I'll check them out. Unfortunately all my tools are two hours away until Monday, took them to my daughters house to put a new engine in her 69 c10. I've checked the fluids, master is full, no leaks, no kinks in any of the lines, fluid looks clean. I replaced the master and booster a couple of years ago and they seem to function properly.
Old 04-05-2017, 03:20 PM   #5
custom10nut
custom10nut's Avatar
Hoses and cylinders
both are cheap and easy to replace.
custom10nut is offline   Reply With Quote
Old 04-12-2017, 07:19 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
i would start with the rubber hoses. They can collapse inside and hold pressure if they get bad...
x2
Keith
Convert to disc brakes.
Old 04-12-2017, 11:46 PM   #7
davischevy
davischevy's Avatar
The son in law had a caliper lockup on his Blazer a while back. He changed the hose and fixed it.
I says "why didn't you change both hoses", he says "nothing was wrong with the other one".
The next week the other hose went bad.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 04-05-2017, 04:34 PM   #8
raggedjim
raggedjim's Avatar
I also vote hoses, been there done that...
raggedjim is offline   Reply With Quote
Old 04-05-2017, 06:57 PM   #9
RGT
I have had hoses that look good on the outside do it also, the inside lining separates and it acts like a check valve.
1971 C10 long bed, fleet side. 200R4 Auto, leaf spring rear. power steering.
RGT is offline   Reply With Quote
Old 04-05-2017, 08:32 PM   #10
Aptosdude
Sticking pistons? Maybe the calipers need rebuilding.
Aptosdude is offline   Reply With Quote
Old 04-05-2017, 09:42 PM   #11
midniteblues
midniteblues's Avatar
I've had the hoses lock up the brakes like a one way valve.
And I've had a sticky piston in a master cly do it too.
This can get tricky during bleeding.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 04-05-2017, 10:12 PM   #12
HO455
HO455's Avatar
Were both brakes stuck? What were the symptoms? The odds of both hoses or calipers being bad are pretty high. Even if it was a bad hose on one side and a bad caliper on the other side. I would look at the master cylinder first. Or a pinched line between the master cylinder and the Tee on the front cross member would be easier to rule out. It is also possible that you have a drum brake master cylinder and it has a 10 lb residual valve that is trapping fluid and as the fluid gets hotter it expands and forces the caliper to apply the brakes. Once the fluid cools the pressure fades. This kind of problem only occurs when you are really working the brakes. Hope this helps.
Good luck.
RIP Bob Parks.
Old 04-05-2017, 10:22 PM   #13
davischevy
davischevy's Avatar
Hoses.
Been there and done that.
Several times.
other Larry
Old 04-06-2017, 12:04 AM   #14
LockDoc
The Older Generation
LockDoc's Avatar
I just had that happen on my '72 Dually. Mine was only the right front but I replaced both hoses anyway. Hoses looked good, but I haven't had any problems since.....
LockDoc
Leon
Old 04-05-2017, 09:18 PM   #15
towbar
towbar's Avatar
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
Here's a quick and dirty way to tell if its the hoses or calipers. With the brakes stuck, open the bleeder valve on the caliper....if it releases / frees up, then its the hose. If it doesn't, then its the caliper.
towbar is offline   Reply With Quote
Old 04-06-2017, 08:54 AM   #16
67 chevelle
67 chevelle's Avatar
It could be many other things besides hoses .
If you replaced the master and its too close to the booster it will do this same thing , usealy when hot , if you have rear drums , drums are kind of self actuating , and your hose from the dif to the crosmember is bad this could very well happen , they will lock or just not work at all . I assume the front brakes are newer , so those hoses are newer .
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 04-07-2017, 08:36 AM   #17
snipescastle2
snipescastle2's Avatar
Talking Re: What's making my front brakes lock up and stay locked up?
Sounds like collapsed hoses to me too.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 04-07-2017, 10:27 AM   #18
AirSpeed
AirSpeed's Avatar
Thanks all! I'm going to replace the hoses, shoes and calipers. No sense messing around! Found rebuilt calipers at NAPA for $25 each, probably cost $150 to do everything so I may as well get it right the first time. Master cylinder is new as is the booster so hopefully I won't have to mess with those!
Old 04-06-2017, 08:10 AM   #19
One hose can start collapsing before the other but you don't notice till the other does. Lots of originals still on these trucks that look great. It's not unusually for both to have the issue after 45 years.
Opening the bleeder(s) test will tell the tale.
Old 04-12-2017, 01:29 PM   #20
AirSpeed
AirSpeed's Avatar
Turned out the caliper was seized up. The piston was absolutely stuck. I took the old hose off and it still wouldn't move. I flushed all the old fluid out of the system to make sure no crap was in there. I went ahead and replaced the callipers, pads and hoses. Need to bleed them again as they're a little spongy but my helper (wife) had to leave. Hopefuly I can get the proportion valve centered, the light is still on.
Old 04-12-2017, 02:12 PM   #21
Stocker
20' Daredevil (Ret)
Stocker's Avatar
To center that prop. valve try stomping on the brakes really hard. Often does the trick.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 04-12-2017, 04:37 PM   #22
davischevy
davischevy's Avatar
I'm sure you will get the brakes working properly. But to clarify, is the wife coming back?
other Larry
Old 04-12-2017, 05:59 PM   #23
Aus69c20
Aus69c20's Avatar
This is unlikely.
But I had the same issue and it ended up being a split pin behind the booster rotating and jamming against the firewall. I put in a smaller pin, folded it over good and no more problems.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 04-12-2017, 06:13 PM   #24
davepl
davepl's Avatar
I dunno, he says "front brakes", as in both, which can't be the hose (unless both magically did the same thing at the same time, highly unlikely).
If it's both, it's gotta be in the master, doesn't it?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-12-2017, 06:50 PM   #25
Aus69c20
Aus69c20's Avatar
Yeah I agree davepl.
But I would have said it was my front brakes as well ( they were smoking).
I figured though unlikely it was the easiest to check.
John
