Stripping a LS donor truck - Newbie!
Hey every one! New guy here looking for some direction. I just picked up a '00 Silverado to pull the engine from to swap my '71. The donor truck is a Z71 (4x4) so I will not be using the transmission, but aside from the obvious (engine, harness, pcm) what else should I pull from this thing? It is a complete truck!
![]() ![]() Join Date: May 2015
Re: Stripping a LS donor truck - Newbie!
If its dbw be sure to get the gas pedal..engine ..maf sensor..engine wiring harness unless your buying aftermarket..the ecm....that's about all your gonna need from the donor truck
It's dbc, so no worry with the pedal. I'm just trying to make sure I don't overlook anything before I send this rusty turd to the crusher lol
![]() Join Date: Aug 2004
Cruise module and cable if you want it.
I would pull the trans to swap for a 2wd trans
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Only other thing might be the air box..but only ifn you want to use it..I went alum tube with a spectre filter on the end..
#6 | |
Nice tip on the cruise! Is there a safety switch or anything for the break pedal I may need? The 4wd trans is trashed. So no luck there. Transfer case broke and destroyed it all |
I didn't use the airbox..I was just saying some people use the donor airbox in their swaps..some look like it came from the factory that way..not sure about any sensor on the airbox
may want to get the throttle cable to reuse if you need to and whatever you can get to use from the fuel system
I did keep my doner air box and now plan on swapping the cone air filter out for factory to help reduce the intake noise.
I also used the fuel pump and some of the lines to the engine.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
that should be enough to get you where you want to go.
You only need the cruise box and harness your already getting I believe. I found a stalk from a mid 70's van works best. There is a cruise thread here somewhere, lsnova is a guru with cruise.
http://67-72chevytrucks.com/vboard/s...d.php?t=511477
Fabricate till you "puke"
I strip em , like an old indian did the buffalo! the 4wd parts are worth some coin, as are the doors, or any decent sheet metal, AC compressor/heater parts,ect. I have parted 2 trucks, & have 2 free engines/harnesses, & a free 4l60 trans
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
