![]() Join Date: Jun 2005
73-87 exhaust on a 67-72
I have searched but I cannot find an answer to the question: Will a 73-87 exhaust system fit a 67-72? I need a 2.5" system for my '70 SWB but I do not have $500 plus for a system. Local exhaust shops want that for a non-mandrel-bent system. I know I do not NEED mandrel-bent pipes but that is what I want. If anyone has installed the later kit please post!
TIA, Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Re: 73-87 exhaust on a 67-72
If you have a leaf spring truck you can probably make it work. If you have coils then nope.
I have coils...
And that is why so many of these coil spring trucks have cheap headers, short pipes and glasspacks with turn downs.
I have a leaf truck and am doing a big block swap using Corvette manifolds. It is going to require a custom exhaust that I will run through the trailing arm crossmemeber. And with me providing mufflers will run about $600. Ouch. But not a lot of choice.
firedemon I will be running 2.5" pipes. The LMC kit is 2.25.
Mike C I will be running mine through the TA xmember also. I also am running a big block. I was going to get the Pypes kit but the outlets on the x-pipe are only 13.5 inches apart and that is too close to run it through the xmember.
