Old 04-11-2017, 07:50 AM   #1
Kainedogg
Kainedogg's Avatar
Red face 1984 C10 4 pin brake switch question
A few questions:
What is the purpose of the 4 pin brake switch in my truck that does not have cruise control.
I have a 4l80e installed, can I reuse the 4 pin switch to lock up my torque converter.
Science flies you to the moon; Religion flies you into buildings.
LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html
C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/
Kainedogg is offline   Reply With Quote
Old 04-11-2017, 08:12 AM   #2
Bigdav160
Bigdav160's Avatar
Re: 1984 C10 4 pin brake switch question
'84 would have had a lock up torque converter (provided it had an automatic transmission).
One set of contacts will be Normally Open and the other Normally Closed.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 04-11-2017, 08:47 AM   #3
Kainedogg
Kainedogg's Avatar
David, thank you. I did not know the TH350 came with lock up capability.
Old 04-11-2017, 08:43 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
It doesn't, but the 700r4 did. My guess is they had run a single part # for the brake switch and just didn't wire it if it wasn't needed in that configuration. My guess is the manual trucks have the same brake switch. Yes you can reuse it, just make sure that its normally open/closed configuration matches what the 80e wants, otherwise you'll be trying to lock/unlock at the wrong command.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-12-2017, 08:47 AM   #5
ls1nova71
ls1nova71's Avatar
They made 350 turbos with lock up converters in the 80"s.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-12-2017, 10:06 PM   #6
Bigdav160
Bigdav160's Avatar
1981 until 1986 (in pickups)
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 04-13-2017, 09:01 AM   #7
solidaxel
solidaxel's Avatar
Yes my 84 El Camino had a 350C THM which was a lock up T C
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-13-2017, 07:33 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
This is news to me.
Old 04-12-2017, 12:03 PM   #9
Kainedogg
Kainedogg's Avatar
BR3, how will I know for certain whether it is in sync with my needs or not?
Do different model 4l80e's have varying requirements from their switches?
I hav a copy of HPtuners and the box, can I use that to determine whether or not the TC is locking up and unlocking when the brake is depressed?
Old 04-12-2017, 09:03 AM   #10
Street Smart
Street Smart's Avatar
It could also be for the cruise control system if it had that option.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 04-12-2017, 09:53 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
4l80e needs 0v on the switch when the brakes are applied. Some switches work the opposite. Just throw a meter on it. If you have the wrong one, I have the correct part listed in my build (pic and part #), a few pages in.
Old 04-14-2017, 09:30 AM   #12
Kainedogg
Kainedogg's Avatar
Al always much appreciated.
